跳转到主内容
7th Gen Amazon Fire HD Tablet was released June 2017. It has since been discontinued and replaced by the current Fire iteration.
6 个问题 查看全部
Cracked LCD and touch screen on Fire 7 9th generation
I got REALLY upset and destroyed the screens of the tablet. The digitizer, LCD everything. I found a new screen for it, and I want to buy it! But here is the problem, I have no tools! Are there any household items that would work for any tools I would need? Thanks! -Blackcomb
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Indeed! you could use a hairdryer to loosen the LSD Tweezers for any inside work. But a wedger is needed along with a suction cup
完成的
添加一条评论
1个答案
最有帮助的答案
@blackcomb there really is no good substitute for the right tools. All you would need is a set of small screwdrivers and a couple of guitar picks to remove the screen from the case. You could use a good hair dryer to loosen the LCD. All of that should be relatively easy to come by. This shows how to replace the screen.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Blackcomb6.1 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 40
总计 423
