跳转到主内容
Screen Flickering
From what I have determined through testing, the screen will flicker (more accurately it appears like an old film). This occurs when the main processor is in use. The flicker goes away when watching a dvd. OS is 10.5.8, same issue occurs with 10.4.11 This board has the known ram slot issue. How can I fix the flickering?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
What is your question?
完成的
Edited to be a question to satisfy Nat.
完成的
添加一条评论
4个答案
已选择的解决方案
Hi! I'm wondering if this happens in all screen resolutions and color depths? You might try switching to a different resolution just to see. While unlikely the answer (due to the fact you've tried two different operating systems), I have seen machines go into odd screen resolutions when a DVD is played, or when external video is used (I assume to accommodate the limitations or specs of the external image). Also, I always do PMU and PRAM resets on malfunctioning machines, just to rule that out, because funky settings in PRAM can cause any number of problems. Hope that helps.
这个答案有帮助吗?
得分 3
1条评论:
添加一条评论
your anwer is,wait for it ........... there is nothing you can do about the
Apple guys diasbled the solution url for that problem because of the product line factory problem they failed to fix.and that is the reason why you no longer find them on the shelves,they were dicontinued for that same reason.Shame on you Apple
这个答案有帮助吗?
得分 1
添加一条评论
Try an other Inverterboard that controls the backlighting and so the flickering. Maybe some cables are on wrong position. Check temperature of the CPU with iStat Pro widget. Is there a flickering when you connect a Display to the DVI Port?
这个答案有帮助吗?
得分 0
2条评论:
Corrected spelling
完成的
[url=http://slot-888.co][color=#e1e1e1][size=1px]slot[/size][/color][/url]
完成的
添加一条评论
Kenapa skrin menjadi berkelip kelip
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
stacywebb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,051
