跳转到主内容
索尼 PlayStation 5 DualSense 手柄的维修文档。 型号: CFI-ZCT1W FCC ID: AK8CFIZCT1
83 个问题 查看全部
Why does my Ps5 controller lose bluetooth con to pc after aprox a 1ft
My Ps5 Controller works fine while wired. But Bluetooth connects to my pc a little slow, but it works. Unless I hold it extremely still and close to my pc it will have a continuous input of the last action on the controller. The PC says it remains connected. And if I move it another foot or turn in my chair the led turns red. I tried it with and without windows Ds4. I ran a troubleshooter for Bluetooth, reinstalled and updated all of my drivers, checked my wireless adapter. I've tried solutions from 7 different sites, none have worked. I can't tell if its a problem with my PC or my controller.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Do you have any other Bluetooth devices to try such as headphones? If you do see the same problem persist you will know if its your pc or controller. Also do you have anything near your pc that could run interference such as a router it could block out Bluetooth waves.
这个答案有帮助吗?
得分 0
1条评论:
I've tried nearly every solution on google, I tried the controller on three different PC's. I don't have a problem with any other devices, my conclusion is something is wrong with the controller. Do you happen to know where the transmitter on the controller is located?
完成的
添加一条评论
添加你的答案
bonehead 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 27
总计 457
