跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
247 个问题 查看全部
heatpipe outgoing & incoming air on hwmonitor is 128 degrees
Hello this is Emre - Apple Technical Service owner,
I have my wife's A1707 macbook pro and ordered a battery 3 days ago. Changed it very well (I don't think that I have destroyed anywhere that time) but then I realised that macbook started to work so slow and did diagnostic and gave me PFM006 & PPN001 as everyone gets. But this didnt mean anything for me. So kept searching and found your video on youtube which shows kindly similiar problem. I have made an external mac os, run the hwmonitor and found only heatpipe incoming and outgoing air is around 128 degress. There is no damage on the card when I checked. I checked the trackpad and saw nothing there. Maybe Im missing of course something but really I couldn't find anywhere to look and Im totally new on macbooks. And the fans goes to the highest speed when mac os starts loading. No CPpu heating on hwmonitor too. Only heatpipe outgoing and incoming airs are so high.
Anyone can show me a way for this?
Thank you in advance
Emre
Edit: I have checked the new battery with coconut app and shows good for the battery too.
Edit 2: Board has been tried with screen connector and trackpad connector plugged off and the result was same for both. And also Battery removed and same result. I have checked the voltages on R5390 and R5391 both have 3.3volts on their "1" pads.
Edit 3: I have took out U5850 & U5800 and desoldered them but nothing changed.
Edit4: Checked the voltages on U5820, getting 3.3v on 1,4 and 6 legs
EDIT: And I just realised that kenel_task use 500% of the cpu
Update (05/09/2022)
Hello again @danj ,
I have changed the battery but same problem is keep going on. I have turned the pc on waited a bit and here are the screenshots of TG Pro, Activity Monitor & HWMonitor.
Do you suggest anything else for me to look? Or where do I need to start?
Thank you
Emre
Update (05/09/2022)
Hi @danj
Please forget about my all posts. I have found the problem on trackpad. I think I have ripped off some components from trackpad while I was taking out the battery. I didnt think that there is a problem as system has detected the trackpad.
But as you can see I have circled the missing components on photo. I dont have any similiar trackpad in the shop so I cant even know what they are. And I think there is no schematics for trackpads.
So is there any possibility if you have the san trackpad for A1707 can you measure the missing parts and let me know what they are and is there any possibility to send me a deeper photo for those 4 areas to check if there is anything else wrong?
I think I have ripped off the sensor from there and I think I found it luckily but I dont know if it is right one so just for the way to put it back and check if it is the right part that I ripped off I need those deeper photos.
I know you are busy enough but will be so glad if you can help me with these.
Thank you
Update (05/10/2022)
Hello @flannelist yes just found out that it is a tmp421 sensor I knocked off. I have done the missing pads and thank you very much for your effort to help me. I have lots of boards of different types of macbooks and imacs. I hope one of them may have it on themselves. The other missing ones are capacitors so I wont be worrying about them. All I need is to find this sensor on other boards now.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Lets get a better view of the thermals, install this great app TG Pro it will allow you to see more clearly what's happening. adjust the main window so all of the sensors are visible (not needing to slide the window) and take a snapshot and post it here for us to see 在已经存在的问题里加入图片
完成的
Photos has been added Dan
完成的
@metech - I'm confused?? I was expecting a snapshot of ALL of the sensors not the diagnostic bar. Let me be clearer open the application fully so the who screen is now showing it not take a full screen snapshot so every horizontal bar is visible. You may need to slide the slider down to get the ones at the bottom.
完成的
@danj Just sorted it I did uploaded but had a problem I think. Just added that photo too
完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
@metech - OK, so it appears the thermal sensors are all working (was there one or two more under the last visible SSD sensor??)
I'm thinking your battery is defective! It has both current and thermal sensors which maybe failing. PFM006 is a sensor failure we've ruled out the thermal sensors which you have shown in the snapshot.
I would contact the battery seller to get a new one.
这个答案有帮助吗?
得分 1
6条评论:
Thank you very much. Doing it right now
完成的
@metech - Happy to hear you where able to isolate the issue down to your trackpad. Sorry, I don't have one to dissect to figure out what the values are.
完成的
@metech I don't have one for an A1707, but I do have one for an A1706, I know they are not the same size, but it would not surprise me if the circuitry were the same/similar. I can check and see when I get home. Mostly posting this so I don't forget.
完成的
@flannelist you are a star I hope it works. Thank you very much 🙏
完成的
@metech Sorry for the delay. Totally forgot last night, but remembered this morning. Looks like the layout is a bit different on the 13" model. Uses the same chip, but components are not in the same place. I have been meaning to do some mapping on it anyways (which is why I have one laying around), I'm on phone duty for a project at work this morning which has yielded shockingly few phone calls, so I will see if i can find some data sheets and come up with a theory. The pics you uploaded though, certainly look like something could have been knocked off.
完成的
显示更多的1条评论
添加一条评论
最有帮助的答案
SO. After my last comment. I managed to find the thing I think you knocked off, it's just in a different section of the PCB on the 13" model. It IS in fact a temp sensor. And even if you cannot find it, should be something you could get easily from an electronics vendor, though it looks like there are some missing pads on yours, so you may have to make some jumpers to get it to work. But. The missing chip, which is present on my A1706 is a Texas Instruments TMP421. Here is the picture of the chip on the trackpad I have. Looks identical to an item that's missing in your second picture.
I suspect the orientation would be the same, given the surrounding components look identical. Sorry about image quality. I don't have a scope at work so this is just off my phone. But hopefully this is good enough to get you what you need.
这个答案有帮助吗?
得分 3
2条评论:
When I checked Texas Instrument website there are 2 different types of tmp421 I think what we need is SOT-23 one not DSBGA. And as Im not surprised we dont have anywhere who sells these sensors in Turkey :) I need to order them from Aliexpress again.
完成的
Ouch. I would check on any iMac displays you have laying around, if any. It looks like they were commonly used on the TCON boards for a bunch of iMac models.
I also found there were supposed to be some of these on the 820-00875 board (that would be a 2016 13" Pro, with function keys), both for WiFi temp sensor and for Thunderbolt temp sensor, but it looks like they didn't make it to the final version of the board.
完成的
添加一条评论
添加你的答案
Aydoğan Emre GÖKTEPE 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 15
总计 297
