Hi @valmy ,
Some things to try to isolate where the problem is and what to do to fix it once you know.
- Try calling your own number from the phone and ensure that you get the engaged tone. If you don't and you get a click or ringtone, unless you have set your number to be immediately re-directed on incoming calls to another number, you're not using your allocated phone number but another one. Check your redirection settings or contact your landline service provider.
- Try turning off the phone's answering system just in case there is a problem with it. On the base station press Answer On/Off (the indicator light should turn on/off in response) or from a phone press Menu # 3 2 7 to turn off and Menu # 3 2 8 to turn on. Call your number from another phone e.g. mobile phone and check if the phone rings OK
If still no good:
- If the base station is connected to a telephone cable socket:
Call your phone number from another phone e.g. mobile phone and then when it "clicks" in the other phone, pick up and answer with your phone and check if you can talk between the two phones OK.
If you can talk OK between the two phones, then try connecting a corded phone to the phone socket, in lieu of the base station and then call your number again and check if the corded phone rings or not.
If it rings OK then you have a problem with the base station.
If it doesn't ring or if you don't have a corded phone, unplug the base station (or corded phone) from the telephone socket (is it the only one on the phone line into the premises or are there more with other devices connected?) and try again and check if there is ringtone in the calling phone or if it clicks and nothing.
If it clicks then you have a line fault. Contact your landline phone service provider about the problem.
- If the base station is connected to a modem:
Try connecting a corded phone to the modem in lieu of the base station and call your number from another phone and check if it rings OK.
If it does then there is a problem with the base station.
If not or if you don't have a corded phone, try resetting the modem by turning it off and disconnecting the power to the modem. Leave it off for a couple of minutes and then reconnect the power and turn it on. Allow it to initialize and settle (may take some minutes to do this) and then try calling your number again and check if it rings OK.
If it still doesn't ring you may have a faulty modem. Also check the phone settings in the modem to make sure that they're all correct.
