跳转到主内容
Repair and disassembly guides for child car seats.
1 个问题 查看全部
How to repair Evenflo revolve 360 stuck
Evenflo revolve 360 got stuck, won't turn or revolve.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
https://www.evenflo.com/pages/revolve-36....
Scroll down to "I tried to rotate my Evenflo Gold Revolve360, but my seat got stuck and will not move in any direction now. What do I do?"
Directions state:
First, squeeze the recline adjustment handle (located behind the car seat) and adjust the car seat into the fully-reclined position – even if you plan to rotate the seat for forward-facing use. If you are having difficulty reclining the car seat, try the following: squeeze the recline adjustment handle, pull up slightly on the back of the car seat and then push down quickly and firmly on the car seat back.
Once the car seat is in the fully-reclined position, squeeze the rotation handle and rotate the car seat to either the rear-facing or forward-facing position.
Please note that the fully-reclined position becomes the fully-upright position as you rotate the car seat into the forward-facing position.
If you still are unable to get the car seat to recline or rotate, please contact ParentLink at 1-800-233-5921 (U.S.) or 1-937-773-3971 (Canada), Monday – Friday, 8 am – 5 pm (EST).
这个答案有帮助吗?
得分 4
7条评论:
Thank you very much. It was very helpful & fixed the car seat.
完成的
Thank you I was losing my mind and now I see the black handle where the rear harness is for the seat. This worked I did not even realize that was there.
完成的
That is not helping me. Seat is stuck. Been this way 3 days
完成的
Hey so I had to very forcefully pull on the back of the seat to get it unstuck. Enough force that I thought I was going to break it and it released
完成的
Try some 99% isopropyl alcohol and cotton swabs
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Edralin Baquiran 将永远感激不已
浏览统计数据:
过去 24 小时: 53
过去 7 天: 398
过去 30 天: 1,609
总计 27,363
