跳转到主内容
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
368 个问题 查看全部
Why does my console take super long to load games?
One day after I decided to play on my console I noticed that it was taking a very long time to start and when I tried playing it took WAY longer for games to load than it used to. It’s gotten to a point where navigating the console settings has become super tedious as well because of how long everything takes to load.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Hey there! I feel your frustration with your console taking forever to load games. Not fun at all.
完成的
添加一条评论
2个答案
最有帮助的答案
Good afternoon,
As you may know storage drives will perform slower when they are full (Or close to). Although this rule holds up, if it takes longer than 5 seconds to move between menu items then something is really wrong here.
Often times hard drives can spit out warning when they are really old (Rolling on my g'ol friends at ltt).
Lets try this: Bring your ear close to the PS4 at these 3 stages
  • Startup: When you turn on the PS4 if it is louder than the disc drive that would mean it's time for a new one
  • Idle: When it's just sitting on the home screen is it obnoxiously loud? This is another sign that it needs replacement
  • Loading the game in question (Please let me know ASAP): When loading up that game (And all the others) Is the hard drive spinning at really high RPM's? I wouldn't say that's hard drive replacement level.
  • It is also a good idea to check if the fans are really loud at these three stages. This means it's overheating and thereby throttling. If this is the case then either: Replace the thermal paste or diagnose it to a component around the board.
Apart from that I don't really know as I am not a technician on PS4's. Someone who would be better fit to solve this would be @jayeff or @danj. I'll leave this with them as they are a lot more experienced at this.
这个答案有帮助吗?
得分 2
1条评论:
@np_f1_2021 - I'm not a gamer so I have no knowledge on how to approach this issue. True drives slow down when you have too little free continuous space more so in HDD's with SSD's Wear Leveling kicks in which slows you down and is often a sign the drive is about to fail soon if you don't clean things up in either case.
完成的
添加一条评论
Hello this is Maxed Out IT
SO check the reset the ps4 just put it in safe mode and reset it that is what fixes it most of the time of that doesn't work then it might be the HDD IF that is the case go to this website a lot of fixes are on it those might fix it wish you luck
https://www.ps4storage.com/ps4-is-slow/
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Gregory Garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 33
总计 551
