跳转到主内容
A smaller version of GM's rebirth of the Hummer.
22 个问题 查看全部
How to replace squeaking belt pulley.
My 2006 H3 just started squeaking on startup and continues for several minutes while driving. How do I replace the pulley that is squeaking. I am not sure what it is called, but it is the one that is on the top left when looking at the engine from the front.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
I am agreeing with Phillip but would like to add the service manual procedure for your H3. It will also help us if you let us know what engine size your H3 is.
"DRIVE BELT SQUEAL DIAGNOSIS
Diagnostic Aids
A loose or improper installation of a body component, a suspension component, or other items of the vehicle may cause the squeal noise.
If the noise is intermittent, verify the accessory drive components by varying their loads making sure they are operated to their maximum capacity. An overcharged A/C system, power steering system with a pinched hose or wrong fluid, or a generator failing are suggested items to inspect.
Test Description
2: The noise may not be engine related. This step is to verify that the engine is making the noise. If the engine is not making the noise do not proceed further.
3: The noise may be an internal engine noise. Removing the drive belt and operating the engine for a brief period will verify the squeal noise is the drive belts or an accessory drive component. When removing the drive belt the water pump may not be operating and the
engine may overheat. Also DTCs may set when the engine is operating with the drive belt removed.
4: This test is to verify that an accessory drive component does not have a seized bearing. With the belt remove test the bearings in the accessory drive components for turning smoothly. Also test the accessory drive components with the engine operating by varying the
load on the components to verify that the components operate properly.
5: This test is to verify that the drive belt tensioner operates properly. If the drive belt tensioner is not operating properly, proper belt tension may not be achieved to keep the drive belt from slipping which could cause a squeal noise.
6: This test is to verify that the drive belts is not too long, which would prevent the drive belt tensioner from working properly. Also if an incorrect length drive belt was installed, it may not be routed properly and may be turning an accessory drive component in the wrong direction.
7: Misalignment of the pulleys may be caused from improper mounting of the accessory drive component, incorrect installation of the accessory drive component pulley, or the pulley bent inward or outward from a previous repair. Test for a misalign pulley using a
straight edge in the pulley grooves across two or three pulleys. If a misalign pulley is found refer to that accessory drive component for the proper installation procedure for that pulley.
8: This test is to verify that the pulleys are the correct diameter or width. Using a known good vehicle compare the pulley sizes." Again, this is from the GM service manual and even so it recommends to do something,I'd be cautious running it without the belt for to long:-)
I hope this will help a bit. Once you can give us your engine size and are for certain that your pulley needs to be changed, let us know so we can get you the right information.
这个答案有帮助吗?
得分 3
2条评论:
+ Do you have EVERY manual ever made?! Nicely done. You're my new source ;)
完成的
:-) no sir, only the important ones.
完成的
添加一条评论
John,
My, guess is that you need a belt and not a pulley. Pop open your hood and inspect the serpentine belt. See if it looks frayed, worn or even if it has a "cooked" kind of look to it (likely caused by the slipping). If it does, all you need to do is release the belt tensioner, slip off the old belt and put on the new one! The unit on the bottom left of this picture is the tensioner.
As a side note, you may find that the tensioner was loose for some reason. If the tensioner is loose, I would recommend replacing the belt anyways, as it may have been damaged.
这个答案有帮助吗?
得分 2
添加一条评论
Spray some water on the belt with a water bottle when the engine is running. If the noise goes away, then it's a misaligned or worn belt . If the squeaking or squealing continues after being sprayed with water, it's a bearing on one of the pulleys or components bearing, such as the a/c compressor or the alternator bearing.
Belt misalignment can usually be seen by an uneven gap between the belt and each side of the "valley" of each pulley, or an excessively worn idler pulley, which is seen on older vehicles when the plastic wheels will wear a "lip" on each side, causing the belt to slightly twist.
Whatever you decide to do, just replacing the belt might buy you a little time before it starts squeaking again, but it's a band-aid fix. The more important part is finding the CAUSE of the squeaking, rather than treating the symptoms.
You can lay a straightedge ruler across each pulley from different angles to check, or just close inspection and listening usually shows what pulley is the culprit.
If you decide to replace the belt, throw the old belt in the glove box or store it somewhere in the vehicle. If your new belt breaks in the future, you'll have a spare to get you off the side of the road.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 8,576
