How do I repair the window in the front driver door
How do I repair window in front driver side?
You may use WD-40 lube spray. I had to pull my window up and down as much as possible! Then I attached the straw that comes with the WD-40.
Then I sprayed the tracks and other moving parts heaver than usual. Meanwhile I kept moving it up and down until it was free.
Later it successfully began to inch it up. Then I pulled it up and down until it was as new!
It is good to apply WD-40 often as a preventative!
Best wishes!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 25
Hi,
What year is the vehicle?
由 jayeff 完成的
Also, what kind of repair are you asking about? Please be specific
由 brandon k 完成的
