跳转到主内容
20", 23", 和 30" LCD 显示器 发售于2004 于 2010年停产。
99 个问题 查看全部
Why is the screen not on when the status LED is steady on?
I have a 20" 2005 Apple Cinema Display HD that I know works, it works as it should with a 2011 MacBook Pro I have, but I just got a 2017 iMac with the hopes of having a dual-display desktop, and the display is not working as I'd hoped. The status LED stays on, no flashing or strobing or fading or whatever, just a steady on as if it would work normally, but the screen is not on and the iMac does not seem to register that another display is connected. It's as if the Display is registering that it is properly connected to a computer, but the iMac will not acknowledge the Display.
I have checked all the adapters and connections multiple times and I know each adapter works on their own, and the backlight is not burned out as even with a flashlight there is no image on the screen.
Is there a possibility that the display just isn't compatible with the iMac, even though all the adapters are valid? Or am I using a wrong adapter somewhere? Or could it be another problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@tippycat23 "works as it should with a 2011 MacBook Pro I have, but I just got a 2017 iMac ......., and the display is not working" sounds like an adapter issue. How and with what adapters are you connecting the display? It should work if you connect the monitors USB plug to a USB-A port on the computer. that will enable you to control the monitors brightness and for the Video you would need needs a USB-C to Mini DisplayPort adapter and an active Mini DisplayPort to DVI adapter. Check on here for more info.
Look for a USB-C to Mini DisplayPort adapter that says it supports adding an addition adapter.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex Mocine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 50
