跳转到主内容
Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
98 个问题 查看全部
My Keurig makes brewing noises but doesn't brew.
Lately, my Keurig Elite hasn't been making full cups of coffee, and just today it finally decided that it no longer wants to brew anything at all. I'm at a loss... Is this thing salvageable?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 262
83条评论
paper clip worked for me and cleaned with vinegar good as new!!!!!!!!!
完成的
your a life saver . I did as you said with the paper clip and now my keurig works like a charm. Thank you so much.
完成的
Thanks. On Christmas Day, What a life saver!!
Merry Christmas!
完成的
Thank you, fixed my Keurig this morning thanks to this post!
完成的
Thank you this worked perfectly. It was the main line of the three on top that was clogged. I am NOW drinking my coffee and happy.
完成的
显示更多的78条评论
添加一条评论
36个答案
已选择的解决方案
I had this problem and called the Keurig support number. They helped me fix it. Your tool bag for this project is a paper clip.
First, take out the plastic holder that holds the K-cups. You should be able to turn it a little and it just lifts out.
Once out, take that piece apart. It easily snaps together and apart.
Once it's in two pieces, you'll see the bottom of the small metal tube that pokes the hole into the bottom of the K-cup. Take the paper clip and insert it into the tube and see if you can dislodge any tiny bits of coffee, tea, or whatever you've been drinking. You can run water over the tube while you do this.
Second, lift up the handle in front all the way up. If you look under the lid, you'll see the second set of tubes that inject the water into the K-cup. There should be three tubes. Use the paper clip and clean them out as well.
Put it all back together and get a glass measuring cup. Run three batches of water through the machine without using a K-cup. Each time, note the amount of debris in the water and how much water is being put into the cup. You want the water to be almost clear and the amount to be consistent.
If this doesn't work, keep calling Keurig support. You have a 1-year warranty and if it won't work, they will eventually agree and send you a new machine. (Assuming you have your dated receipt.) My brother got them to send him a new machine because his stopped brewing too. They didn't want it back so he decided to take it apart to see what the problem was. He said he had a split water line, so in that case, no amount of pipe cleaning was going to help.
Good luck. I use my Keurig every day and really like it.
这个答案有帮助吗?
得分 200
145条评论:
We use the re-usable coffee filter on it instead of the K-Cups but I'll check it out... the noise it makes sounds like a strained noise instead of it's normal motor noise... like it's exerting pressure but there's a blockage.
完成的
Thank you!!! Worked perfectly and it even makes decently sized cups now!
完成的
I had this same problem and this answer solved it instantly and easily! Thanks so much, Tim!!
完成的
I thought my Keurig was a goner but this worked like a champ. Thanks so much!
完成的
Paper clip worked! What yucky stuff clogged! I even ran vinegar water through every month and it still clogged. Paper clip saves the day!
完成的
显示更多的140条评论
添加一条评论
Also check the filter in the water reserve. I tried all the above with no luck. I then removed the three screws inside the water tank, took out the metal mesh filter, and tried to run the system. Worked perfectly. I then tested the filter by putting water on it, and it was almost water proof.
这个答案有帮助吗?
得分 22
22条评论:
Check this first if pump sounds laboured truing to refill heated reservoir.....worked perfectly after cleaning screen in cold reservoir
thanks!
完成的
The filter at the bottom of the reservoir is the first thing I check. The mesh looks clear, until you hold it up to a strong light and see a gel-like coating on it.
完成的
Wow I have been messing around with this for awhile and tried this and IT WORKS! Take the mesh out and just use filtered water. Thanks
完成的
Thank you very much. Busted my head over the problem for hours today, then saw this. Solved it quickly. Back to caffeine for me!
完成的
Thank you! This one worked like a charm!!!
完成的
显示更多的17条评论
添加一条评论
I am currently serving in Afghanistan and our Keuring B130 quit working a few days ago. We had to go back to the old fashioned coffeemaker, which was very painful. I was waiting on my wife to send some Keurig Cleaner from the states, when I got desperate and decided to research it on the web. I found your site, used the paper clip trick, and ran two cups of straight vinegar through it and it works like a champ again. The Taliban can sleep easier knowing that we're no longer Keurig-deprived of our caffeine fix. Thanks for the very informative site! Happy Holidays to all from Afghanistan!
这个答案有帮助吗?
得分 19
13条评论:
Happy holidays.. Thanks for ALL YOU do. ......
完成的
I worked on this for an hour before finally reading your instructions. 3 other videos didn't help. Need coffeeeeeee!!!!!
完成的
I have B40 unit and i had a problem with this machine when it was not making enough coffee or won't make any at all. Even though the strainer filter at the bottom inside the reservoir looked clean it was full of lint and calcium when i looked though it in bright light - the stainles mesh used to make that filter is super fine and easily clogged. There are three screws that hold the strainer down. Remove it and put it in vinegar and let it soak. After soaking few hours i took a waterpik water flosser and on high setting pressure-washed it from the outside-in to get rid of all the calcium lint and dust that could have gotten into the water tank. Put the strainer back and screw it together. Make sure when you screw in the screws you have a good feeling of the thread and find the same grove. Since this cleaning it worked like new and exactly the same amount each time for each cup size setting. Hope that works for you my fellow coffee addicts.
完成的
Thank you, thank you, thank you. It worked!!!!
完成的
mine still doesn't work - i had a cup with breakfast this morning and then decided to have a second cup and it didn't work-- i have been trying a lot of different things alllll day - still nothing.
完成的
显示更多的8条评论
添加一条评论
Take the top cover off the brew area removing the two silver screws under the lid where the k-cup is located
Removed the zip tie leading to the water filter.
Lifted the black ring that holds the hose that goes to the needle and pull the hose up
Blew back down that line and lots of sediment will come out from behind the filter
Turn the unit on and let it brew hot water into the holding tank just so you can see if it is cleared
Replaced everything to its original position including putting a new zip tie
on the line you removed.
This is the third Keurig I have fixed that has had the same problem.
Generally, you have to de-scale the Keurig every three months
You don't have to use a whole tank of vinegar.
Put a 50/50 mix of vinegar and filtered water in the tank, run it once
Let the brewer sit for 45 mins so the vinegar can act on the scale
Run it a second time and let it sit for 15.
Then empty the tank, washing it throughly or you will get slime that builds up on the side and at the inlet at the bottom of the tank.
Now run the clean water through the Keurig for a few passes until you no longer smell vinegar.
这个答案有帮助吗?
得分 11
9条评论:
Was just about to drop 150 bucks for new one but decided to take apart and clean out the part with needle that punctures top of k cup. I had water backing into the resevoir and when I cleaned out it works perfectly. I actually brewed hot water thru while holding the waterline in my hand into a mug before I put back together. Sounds weird but I held that piece with metal puncture point on it over sink and blew into it and the grinds just shot out into sink. Soaked that part in hot soapy water put back together and works like it's brand new!
完成的
Thank you so much for this post!
完成的
Thank you so much!!! I took off the two screws, like you said, and followed your directions, now my 10 year old Keurig is back to her old self, making a full cup of coffee great as ever!! I did lose a screw somewhere in the machine, but it seems ok with only 1. I know now not to wait till the descale light comes on to descale I will be doing this monthly now. I had descaled 4 times in a row before finding this site. I did the paper clip thing and nothing helped until I blew it out. Thanks again!
完成的
The screws on my Keurig aren't the kind you can take off, but I used the paper clip, cleaned the screen on bottom of reservoir and then turned it upside down over the sink (nothing came out, but just in case), plugged it back in to descale with vinegar and voila! water came out full force!!! I am a happy camper, thank you thank you thank you! It was taking 4 cycles to get a cup of coffee, and I really didn't want to put out $100+ for a new one. I love my Keurig when it works..... Added bonus: I put baking soda in my sink/tub drains and poured the hot vinegar down to clean them, killed two birds with one stone!
完成的
I have a B70 system. Just tried all the fix-it tricks on here and nothing will help it work again. I can't get one of the 2 screws under the top lid off. Have unplugged it numerous times and then turned it back on. Even left it unplugged for an hour at a time...still nothing. I can still set all the programming and it blinks and says 'Ready to brew' but about 2 teaspoon of water streams out and then it stops and gets stuck on "Brewing" mode. Don't want to buy one of the new models out there now. Have had this one since late 2008 so maybe it's outlasted it's usefulness....
完成的
显示更多的4条评论
添加一条评论
I took the two screws off under the lid opened it up and discovered one of the pump hoses came off. I put it back on and it was good as new. It was easy to get the lid off. Just Need a small Phillips head screwdriver and a flashlight to see.
这个答案有帮助吗?
得分 8
9条评论:
Same issue here
完成的
Mine has the screw heads that the smallest Phillips screwdriver not an option - they have it like an octagon as if they do not want you to allow your own repair - any suggestions?
完成的
Carla - Mine does to! Did figure it out?
Malisa
完成的
Mine makes a humming sound and says not ready and then turns off automatically I'm trying to unscrew things and see if it is blocked. It was working when we left for the summer but didn't brew coffee when we just returned. Hmmmmm
完成的
Never heard back from anyone. After working on it, I finally got it to work. My daughter said she just returns it to Costco and replaces it
I did lose a screw but it works. Now need to clean out the vinegar
Joanne
完成的
显示更多的4条评论
添加一条评论
I had this problem with my single cup unit after it had sat unused for three months. Tried the paper clip, no luck. Then I found a post elsewhere that said that if the pump dries out, it can't re- prime itself. I took a turkey injector without the needle, filled it with water and placed it over the hole in the bottom of the reservoir and gave it a strong blast of water until water came out where the coffee normally does. That did the trick.
这个答案有帮助吗?
得分 4
5条评论:
I had the same issue and this did the trick! Thanks for sharing, now I can have my morning coffee again
完成的
The screws are impossible to remove.
完成的
I'm still fighting with getting it to suck the water through the system. The WaterPik idea seemed to take care of the mesh opening at the bottom of the reservoir -- used WaterPik first on mesh side, then flipped empty reservoir over at a sink and blasted Pik through the outside bottom opening of the reservoir, then I blew air from my mouth through bottom and heard it coming through into reservoir. BUT there still is someplace between reservoir and the 3 needle-holes under lift-up lid that is blocking the flow. Can occasionally blast a small amount of vinegar water with sediment in it out into a cup, but then I try over and over, with periods of waiting in between, to get it to suck more water out of the reservoir, as only less than a half cup comes out the end when it does intermittently work. Sigh. I've always been able to de-calcify the machine before using vinegar and a paper clip for the various operations, but this time I'm getting frustrated.
完成的
Thank you!! I had been trying every other tip I found and nothing helped, but this fixed it right away! I used an oral syringe since that's all I had :)
完成的
I also had this problem of no water being pumped from water reservoir after machine sat for one month. I tried the waterpik trick on the reservoir intake and it completely fixed the issue. I’ve had my machine since 2011, never had to do this yet until now.
Thank you Cal for clarifying about the pump can’t re-prime itself!!!
完成的
添加一条评论
I was in the same boat.. half cup brewing. I used paper clips (very helpful) I read to put the whole machine in the sink and use your pressure hose over the water reservoir for 30 seconds to flush the system which im sure helped clean the lines but caused the water to not siphon. I was one step away from either tearing it apart or throwing it in the garbage when I tipped the whole machine upside down and shook it. IT WORKS PERFECTLY NOW! coincidence? no clue but hey, it works. figured I'd share for all those who are at wits end like I was.
这个答案有帮助吗?
得分 4
5条评论:
Coincidence, I think not. It worked!
完成的
Hi John - Thank you, thank you, thank you - we filled the reservoir with water from the sink, took it outside, and shook the heck out of it. We then dumped the water and banged the bottom. We got clumps of grinds out of the unit. Now it is running like a dream. Apparently it needed a good smacking!!
完成的
I tried the paperclip, which had worked before. This time it did not help. I turned it upside down and shook it over the sink. First it started refilling the reserve well from the overflow lines at the top of the well. On the third try it began working like normal. Yea! Thanks John.
完成的
I tried everything but disassembly - no good. Then I turned it upside down and shook it. Works! Piston under water tank wasn't pushing up on the tank valve to release water. At least that's my guess
完成的
Tried the paper clip several times. Shook it upside down over the sink, the HOT water came out and as I shook it gently I heard a click. Worked fine after that. Thanks for the tip. My Tip: Watch out for the HOT water!
完成的
添加一条评论
Ok...Mine had similar issues. After trying all of these I was still unable to get water to flow. So, I took the head apart. I then removed the hose from the nozzle that is in the head. I started to brewer, carefully holding the hose in a cup. I got some water flow, but not much. I then took the nozzle out of the head and blew through it. Apparently it is a pressure sensitive nozzle and it may have been stuck as I was able to clear it out. I ran the cycle through the brewer several more time before I was able to get good flow through the hose. I then hooked it back up to the nozzle and it works. I just made a fresh pot...good to have you back Keurig.
Be careful with the hose when brewing as the water is very hot.
The burping method may have had the most impact as I would have the machine on and tilt it upside down (water reservoir removed) and I could get some flow.
这个答案有帮助吗?
得分 3
1条评论:
We have never had a problem with our original Keurig. Two things we have done that may have prevented problems. 1) Once a year or so we would run a solution of white vinegar and water through the system (50/50) and 2) was that I always pressed the kcup down in the holder, thereby releasing the pressure and not allowing grounds to go up the water tube. I did that because there were certain kcups were I could stretch the amount of coffee (green mount dark magic) and get one cup of about 16 oz. After brewing my first cup, I would remove the kcup and I would massage the kcup to realign the coffee. I would always place the kcup in the holder at 12 o'clock so that it would be easy to put back in to add to the cup I just made.
完成的
添加一条评论
I placed the kcup pod in the holder,and closed the lid so the pod would get punctured both top and bottom.
Without going to the next step, I lifted the lid up and removed the pod to see if it was getting punctured.
Well, it was not. The top was fine but not the bottom, which was barely punctured.
So I got a pointy knife (pointy nail works too) and made the hole a tiny bit bigger.
The water can now go thru the pod easier.
This happens on those pods that look like they are overpacked.
The air pressure inside the pods forces the coffee grinds into the water line and clogs up the pins.
I hope I'm naming the parts right and that this fixit is understandable.
这个答案有帮助吗?
得分 3
添加一条评论
To help avoid future need to unclog the spout, I have always pressed down on the kcup with my fingers after inserting it in the holder. What this does is it releases the vacuum downward. If you don't do that and close the lid, the coffee or whatever is in your kcup, shoots upward. Then when water hits it, some comes out but some will stay and clog it.
这个答案有帮助吗?
得分 2
添加一条评论
It's been mentioned on this list before but I think the procedure for installing the K-cup is very important. For various reasons K-cups often have pressure built up inside. When the top of the K-cup is pierced, when lowering the lid, the pressure blows unbrewed coffee into the upper needles which can cause a clog. I think it's better to first use your two thumbs to press the K-cup firmly down into the cavity which pierces the bottom and relieves the pressure . That way coffee grounds won't blow up into the upper needles when the head is lowered. As always, good luck and your mileage may vary.
这个答案有帮助吗?
得分 2
1条评论:
I agree. I came to same conclusion with those pods that look overinflated.
完成的
添加一条评论
Use compressed air and back-blow from spike that punctures the K-cup. Then remove water reservoir and blow compressed air through there too. After 4 + years, this was the ONLY fix that worked to dislodge particles in tubing system. Took all of one minute and saved $$$ buying a new unit.
这个答案有帮助吗?
得分 2
添加一条评论
Had the same issue with a clog. I had to remove the two screws under the cover and clean out the hose it's self. Once I completed it ran like new!!! Tried the paper clip but the clog was too much.
这个答案有帮助吗?
得分 1
添加一条评论
Most of the problems are caused by minerals in the water. Take the tank off and see if there is a strainer (if there is back blow with compressed air, you may have to remove it ..3 screws...I did) reinstall and check that water flows freely when valve depressed. Go to store and purchase DISTILLED WATER in gallon jugs (not spring water)...about a dollar a gallon...use this only...My problems were ...add water light on when full...brewing a half of a cup...descale light on...you may want to descale it at the same time...Mine has been working great for about six months...
这个答案有帮助吗?
得分 1
添加一条评论
I have the Breville version, three+ years old. It's a replacement Sur La Table gave me, no questioned asked, when the first one short-cupped after only a month. (I'd owned a Keurig B75 Platinum that had failed twice and been replaced twice by Keurig--and broke again a week past warranty expiration). I use Crystal Geyser water, and sometimes filtered water from the fridge. After it short-cupped sporadically, I descaled 6 mos. ago, which worked for awhile. In the past couple of weeks, not only did it start short-cupping drastically but also took forever to heat and brew. Got so that I had to use my espresso machine to add either hot water or brew a shot of espresso into the black coffee in the cup!
Did the paper-clip thing on the needles and cleaned the reservoir screens--then it heated a full cup of hot water (slooowly) but only a half-cup of tea. Removed reservoir again to unscrew the top in order to check the hoses (housing the My K-Cup holder and scoop) but found and removed only two screws. And the top would not budge, so I put the screws back in. Next, I removed the reservoir again and hit EVERYTHING that had a hole in it with a blast of canned air. Then I dragged the machine to the sink, turned it upside down and shook and whomped it on the bottom a couple of times. Brought it back, replaced the reservoir, plugged it in and turned it on. Had to reprogram it--and this time it brewed a full 7-oz. cup of Sumatra (as swiftly as when new) on the default 7-oz. setting. Keeping fingers crossed. Next time if it malfunctions I will do all of the above plus descale. If that doesn't work, I will let it rest in peace--at its age it's already beaten the Reaper. Would replace it with a Vue were it not for the huge backlog of K-cups I still have (several months' supply, at an average of six or seven cups a day). But meanwhile, I've developed a taste for a "red-eye" (that shot of 'spro brewed into a cup of coffee). ;-)
这个答案有帮助吗?
得分 1
添加一条评论
I found the metal screen mesh in the bottom of the water reservoir was starting to plug up with lint after 2 years of use. It was impossible to see until I removed the 3 screws holding it down, and took it out. Washed it with water and it fixed the problem.
这个答案有帮助吗?
得分 1
添加一条评论
Follow up to "Mark" Our cups seem to be under pressure, not vacuum, possibly due to altitude (over 5k ft). I push them down so the needle punctures the bottom, then repeat after turning the cup until there are 6-8 holes in the bottom. Also have better luck with the plastic k-cup you fill yourself. Before this my brand new machine was clogging and short cycling starting with the second cup!
这个答案有帮助吗?
得分 1
添加一条评论
I was getting the descale indicator even after descaling, and either no brew or an espresso-size brew when set to 12 oz. A few things I've learned to get it back to work, needing a combination of all these to get back to brewing:
- Don't use a paper clip, you risk piercing the plastic hose above the needle. Instead, I use a gum stimulator, like GUM Soft Piks. They're definitely safe, flexible, and the little bristles scrub the needle innards gently. I use the same piks to clear the inside of the needle that pierces the bottom of the pod - mine was completely clogged, but that wasn't the only source of my problem.
- You don't need to fill the entire reservoir with vinegar to descale, just one standard bottle of white vinegar plus one same-size bottle of plain water should do. The amount of vinegar in the reservoir doesn't matter, it's the vinegar that sits in the tubing that is working to break down the deposits. Be sure to flush with plain water till you don't have any vinegar smell.
- I took the top of the lever part off by removing the 2 screws on either side of the pod-piercing needle, then removed the 2 small screws holding down the tubing between the valve and the needle. I then coaxed the tubing off the valve and used a Q-tip to clean the inside of the tubing (it was a lovely shade of brown) and also the firmer outlet from the valve. I then replaced them as they had been. I replaced the cover of the lever but didn't replace the screws - it stays on very well on its own and will make it easy to remove if I ever need to again (I'm sure I will at some point). FYI, the screws start to strip easily, that's another reason to keep them off, so make sure you have a good grip on them before you start twisting.
- I unplugged and did the whole "flip it over and spank it" stuff, I really don't know if it made a big difference, certainly no more than just unplugging does for just one or two cups, before, in my case, it reverted back to the very short cups. I'm not convinced that unplugging the unit for hours has any great effect that a few minutes wouldn't.
- I used a can of compressed dusting air, with the thin straw it comes with attached, to spray out the entry point into the machine, where it empties from the water tank. Try to seal off that hole as much as possible around the hole, and put a paper towel over it in case it sprays out.
- There is a rubber washer around the needle that pierces the top. You can slide it off and wash it - it has ridges that get clogged up with coffee. This probably doesn't stop the water flow at all, but it is kind of gross.
- Rather than sucking boiling water out through a straw held firmly around the needle, I attached a straw to a squeeze bottle, taped it on to keep it close to airtight, then gave the bottle a squeeze before holding it over the needle, then reversed the suction of the squeezed bottle by squeezing it at its indents. Did this a few times and it created enough suction to drag out more yuck. This made a big difference. The rubber washer noted above can be reversed so that a flat side is making a tighter seal with the straw, just reverse it again when you're done.
Working well again. Hope this all helps!
这个答案有帮助吗?
得分 1
添加一条评论
I tried most of the above suggestions with no success. Finally, in desperation, put baking soda around both water intake filters and then added vinegar. The resulting 'froth' seemed to clear out any gunk that was plugging the filters. Then put vinegar/water 50/50 in the tank and ran it through. Followed with clear water to rinse. It worked!!!
这个答案有帮助吗?
得分 1
添加一条评论
i took the bottom plate off of mine looked at hoses..didnt really see anything wrong with it so i i plugged it back in while it was laying on its side so if there was something coming out where the water tank is it would pour out in the sink and bam water started coming out on its own...unplugged it then put all the screws back in the bottom set it back up and plugged it in. turned it back on and it was working like new..ran thru the steps of running vinger through it and its working like new
这个答案有帮助吗?
得分 0
添加一条评论
After moving mine would not prime, I tried all of the tricks you find on here I was ready to give up. I took the top where the k cup goes in and I pulled the hose off of the one way valve, I then took a meat injector syringe and put it in the hose while blocking the over flow back into the water tank with my thumb I pulled and pushed water thru the the hose until i got hat water coming out of the hose. this will push water into the tank and prime the pump.
it now works just fine.
这个答案有帮助吗?
得分 0
1条评论:
I just tilted mine to one side then the next and this allowed it prime itself. Becareful though very hot water. But that worked for me....
完成的
添加一条评论
I took air hose and connected to rubber safety hose inside water resovoiur and blew out . Took 1 second. Dw
这个答案有帮助吗?
得分 0
添加一条评论
Here's what I did to solve the problem. You'll need a small screw driver, two small ty-wraps, a paperclip, and vinegar and water. Here's the process:
1. Descale the brew machine using the instructions from Kuerig
2. Clean out the exit needles using a paper clip per the Kuerig instructions
3. Clean the one-way valve. This valve is located inside the unit beneath the top cover of the unit. It will gum up and inhibit the flow of water through the unit. Cleaning/blowing it out will fix this issue.
a. Unplug the unit.
b. Remove the water container from the unit.
c. Remove the top cover from the unit. This requires removing the two small screws from
the bottom of the top cover. Open the top as you would to put in a k-cup. The two
small screws are located on the top. You'll need a flashlight to see them.
d. The one-way valve is located on the top and is a larger clear rubber valve attached to
the inlet needle on one end and the hose to the heater on the other end. This end is
secured with two small ty-warps. Remove the two small screws holding the valve in
place. Cut the ty-wraps and remove the valve from the inlet needle and hose.
e. Take the one-way valve and blow it out from the end that was hooked to the
heater hose. I used a small air compressor to clear the valve. You'll see the check
valve move open and closed on the inside while blowing it out.
4. Replace the one-way valve.
5. Replace the cover. This can be a pain since it's hard to see the holes and screws. Be prepared for a few cuss words. If you drop the screws into the k-cup holder you can shake it and they will fall out the bottom.
6. Replace the water container.
7. Plug the brewer in and test.
Now you can run a cup or two through the system. Again I used a small compressor to blow out the one-way valve. This worked best for me and made the repair quick. The unit has been working like brand new since this repair.
这个答案有帮助吗?
得分 0
添加一条评论
I had not used my brewer in about 3 months. I turned it on and the water heated up and I pressed Brew , Nothing. then the water started coming out of the over flow hose back into the water reservoir. My son took a can of compressed air that he uses to clean the computer. Put the hose of the compressed air into the hole that didn't have water coming out of it. As he did this brown water came out of the brewer where the coffee is normally made and filled a large cup. Then we put more water in the tank and he did it again. Not as brown this time. The Brewer now works. brews the correct amount of oz for what is chosen. Thank You Son. works great now.
这个答案有帮助吗?
得分 0
添加一条评论
Take all removeable parts (reservoir lid / reservoir / cup rest) . Unplug & take it to sink / tub or outside table. Take a bottle of water & flip it upside down on the water entry point & force water thru machine ... should unclog asap.
这个答案有帮助吗?
得分 0
添加一条评论
OK, this works. You will need perhaps 1.5 hours+.
I have the 1-cup version, so I pour one coffee cup of water in for each cup of coffee.
This cleaning process is very frustrating at first. If you have a short fuse or limited patience, plan to do this process once per hour over a day, or an evening.
My version -
--paperclip opened up 2 joints - 2 inches+-
--with paperclip, ream out the three valves which puncture the top of the K-cup (be careful - this tip is VERY sharp - check your aim) - if major resistance, you have probably missed the path and are hitting the gasket; the back valve is most difficult to reach accurately
--2 16-oz measuring cups - you can do this with coffee cups, but the measuring cups allow clearance for the funnel and filter; a coffee cup will not
--one funnel, large enough that it sits - mostly - outside the measuring cup mouth
--1 coffee filter, paper-clipped inside the funnel, funnel inside empty measuring cup, empty measuring cup placed to receive the hot liquid, just like a coffee cup; you will use the same single coffee filter repeatedly until cleaning is finished
--10 oz. white (distilled) vinegar; pour the vinegar into the reservoir ; you will repeatedly use this same vinegar throughout the cleaning; don't discard
--power up; open/close gate to load the vinegar
-- when the machine chokes or quits, hold down the BREW key until the machine gargles, indicating all fluid pushed thru - bottom measuring cup will now have 10 oz. vinegar
-- you should see some sediment in coffee filter.
-- move funnel/filter to empty measuring cup; place as a "new empty coffee cup"
-- ream the nozzle again
-- pour the vinegar; repeat steps starting at "power up"
--- at "repeat 10 times", suddenly flow improves; can run an entire cup without holding down the BREW key
-- keep reaming; keep repeating; and after 15-20 cycles, your machine flows like a new machine.
-- now - just as the flow starts, power the machine off and let it sit for 30 minutes; then finish the cycle; repeat
-- Ok, fresh water, several runs, until water does NOT taste like vinegar; and then run water twice more - each run with fresh clean water.
All done.
BTW - some of these observations indicate that a hose was dislodged. This probably occurred because the pressure of the system exceeded the hose clamp, and blew the line off the connection. You are out of luck here, until you actually figure out how to disassemble the machine; beyond the scope of this discussion. If you can manage to get the hose reattached, with a clamp, than follow this procedure to keep the pressure off the hose in the future.
Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
Do the following:
Drain fill tank, Remove charcoal filter pack, back wash fine mesh screen, run vinegar through system when doing this let the brew tank fill, make one cup then let the vinegar sit a few hours..last run plenty of clear water through brewer to remove the vinegar and any scale that the vinegar loosened,, put in a new charcoal filter (you can buy these at the store where you purchased your Kr.. last get a push pin (like you use to tack notes to a bulletin board).. prior to making a cup, use the push pin to make a small hole near the center of the K cup... this will relieve the pressure in the cup...do this for all K cups prior to using your K brewer will most likely never clog again... do the cleaning process about ever 6 months, but again.. use the push pin all the time...
Paul Battaiola
这个答案有帮助吗?
得分 0
添加一条评论
Thanks to all of you for such great help. Due to a move, I had my things in storage for about four months. Unpacked it and tried it tonight, it was a no-go. I researched and found this wonderful site! I tried the paper clip to no avail, then I saw both Mark and Cal's posts about the tube being dried out and a burst of air would push the water through. Well, I didn't have anything to push air hard enough to shoot water through the tube except my bike pump. It did the trick! I just positioned the end of the pump (w/o the needle) right over the water hole. Take the water tank off and you will see it. I pumped hard about three times and water came pouring out of the spot where the coffee comes out. Thanks to all of you!! Susan
这个答案有帮助吗?
得分 0
添加一条评论
After having to hit the button 6 times to get a full cup of coffee (for the last 2 weeks!), here are my two cents worth..... get a small phillips screwdriver, a small flat screwdriver, wire snips, needle nose pliers, 10 small zip ties, some type of small wire poker. THIS EFFORT MAY CAUSE DAMAGE TO YOUR PLASTIC PIECES. Unplug and drain the water. Open the hatch and remove all the screws(4, I recall) holding the lever cover. Remove the cover. Then work very carefully to pry the top back cover from the machine. I was able to get the left side loose pretty easy. The right and back side clips actually broke off of my unit but didnt damage the fit. These were intended as "one way clips" with no option of repairability. I was not too worried about this damage and would rather deal with this than drop another hundred bucks on a new maker.
Flip the unit upside down and pull out the 5 screws holding the bottom on. Make sure not damage the 3 grounding wires attached to this plate. Locate the little pump motor and pull the 2 screws holding the motor. Use your needle nose pliers to squeeze and slide off the small hose clamp holding the accordion hose to the side of the pump motor. Flip the unit back over and clip the big zip tie holding the cluster of hoses below the plastic clip. You are trying to locate the bigger tube that runs down to the pump motor. Once located, clip the zip tie on the bigger tube and clip the similar zip tie on the pump motor and remove the length of tube and check valve. Take this whole thing to the sink and flush out the muck(water and vinegar). Use you wire poker to gently push into the check valve to ensure it is cleaned out and working. Blow into either end of this hose/check valve to make sure you can blow one way but not the other. If you can blow both ways, the valve needs more cleaning and poking.
You will also find a similar check valve under the hatch lever. Cut the zip ties at either end of this unit, remove it and do the same cleaning, flushing and actuating of this valve. The crud that came out of my check valves was pretty bad and was the cause of all my problems.
Reassemble everything you took apart. Make sure to get the zip ties back in place on all the tubes and get the hose clamp back on the accordion hose on the side of the pump. It is easier to feed the bigger tube up through the top of the unit before connecting it to the pump. Zip tie the cluster of tubes back under the black plastic clip. Snap the top back of the unit back in place if the tangs didnt break off and if they did, hold it on with clear tape to cover up the booger marks. Tuck the power cord back into the little horseshoe housing and reinstall the bottom cover with 5 screws.
This is a more advanced home appliance repair but only took me a little over an hour to accomplish. My unit is no longer aesthetically perfect but it made a full cup of coffee on the first and only hit of the button.
PS. I like the "industrial-mechanical" look and may just make a clear plastic cover to reinstall on the top of my maker.
这个答案有帮助吗?
得分 0
2条评论:
You are so funny! Bravo for the considerable effort and congratulations. You deserver a cop of copy for sure!
完成的
That was cup of coffee!
完成的
添加一条评论
I had trouble with the Keurig brewing short cups. It would lose its prime. I found that the model I was using had a very tight fitting lid on the water reservoir. When the Keurig tried to pump water from the reservoir a vacuum was created. The water leaving the reservoir needs to be replaced with something ... and that would be air. The pump was just not able to overcome the vacuum. It worked perfectly with the water reservoir cover removed. I wanted to use the cover so I simply drilled a small 1/8 inch hole in the cover near the back of the reservoir. This is all it took. The air coming through the hole is enough to prevent the vacuum from forming. It's been going strong for over a year.
这个答案有帮助吗?
得分 0
1条评论:
Too late for me. Used paperclip, still no change. Now rubber tubing has hole from paperclip :(
完成的
添加一条评论
Instead of paper clip, try a used guitar string. Works for me and I just did it again. Shocking you can get the guitar string about 3 inches up there because of it's flexibility and the string winding provides a bit of cleaning. Hit it to brew with no cup in and the water is a yellow tint coming out. Just made a cup,,, awesome.
I even keep the guitar string in the corner of silverware drawer. If you're unfamiliar, choose a D or 4th string from someone 's guitar.
这个答案有帮助吗?
得分 0
添加一条评论
FOR THOSE THAT USED THE PAPERCLIP WITH NO RESULTS:
Used the paper clip and it didn't work. I placed a straw over the object that punctures a hole in the coffee pod and blew air through the line- this don't work (btw, the water reservoir needs to be detached if you're going to blow water through the line). I then sucked on the straw once for about 5 seconds and extracted a large amount of water in that short time. Coffee maker works now!!! Water was not running through at all and this fixed the back up in the line. Just as a precaution, the water is extremely hot when you extract it from the machine via a straw you will get a mouthful of near boiling water.....
这个答案有帮助吗?
得分 0
添加一条评论
I had an issue with my Keurig B44 whereby the pump would turn on but it would not draw any water up into the heating reservoir. First thing I checked was the mesh filter inside the holding tank which was fine, I then checked the pump which turned out to be pumping water normally. Next I removed the top cover and found my issue to be the one way check valve was gummed up. I removed this valve and cleaned it out with some hot water and the issue was resolved. Hopefully this can help somebody else out who may have the similar issue.
这个答案有帮助吗?
得分 0
添加一条评论
I have a much easier solution. I unplugged mine for 10 minutes or so...plugged back in, and it worked like a charm!
这个答案有帮助吗?
得分 0
添加一条评论
I had same problem with all of a sudden not brewing and strained motor sounds. I did the paperclip, then the screen and finally tried to brew and it was making bubling sounds so I blocked air from the little plastic drop thing in back of water redivoir that the water container is usually cut out in top for and I put my finger over it and air bubbles we're backing up from bottom. So then water started coming out of the coffee point when I released. The liquid was discolored. I did this a second time and got a full cup of water to come out. I think it was blocked in the tube and that was a way to dislodge it.
这个答案有帮助吗?
得分 0
1条评论:
After all the cleaning, I realized my problem was with the pod not being punctured on the bottom. We have been using the reusable plastic pods which bent or moved the bottom punctured device, very frustrating. These pods also clog the upper needle. We will be going back to disposable pods, unfortunately.
完成的
添加一条评论
Forget the Turkey blaster and use the injector. My Keurig had sat for 6 months or more. All the lights were on and I one site suggested holding the power button on while pushing small, then medium and large. It finally acted (I could hear) the pump trying to pull water. I banged the machine, poked the needles to no avail. I used my turkey injector, almost full and used it to force water into the spring area. After about 4 hard squirts water came out!! Be sure you have a cup at the ready!!! I had to do the squirt a few more times and then I ran a whole dispenser full of vinegar/water and she makes coffee again. Don’t give up!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Skippy722 将永远感激不已
浏览统计数据:
过去 24 小时: 108
过去 7 天: 588
过去 30 天: 2,663
总计 1,468,142
