mower clicks several times before starting
Simplicty consumer zero turn with 20hp Vangaurd. I replaced engine with identical engine from parts machine. starter has always clicked at the starter several times before cranking and starting. so I replaced starter with one from the blown engine. It does the same thing except now it is the solenoid that is clicking.
@moosecow what happens when you bypass the solenoid? Does the starter work when you try that? You double checked all the wiring to make sure it is all snug and properly connected? Good battery?
由 oldturkey03 完成的
