跳转到主内容
加入维修社区 - 创建账户
苹果2019年度的旗舰手机发布于9月20日,该设备配备5.8英寸OLED显示屏、三颗后置摄像头,电池续航能力大幅度的提升。为iPhone XS的后续机型。
Face I'd replacement dot
Hello and sorry for asking so many question I am just new and trying to learn as fast I can, so my question is we have a phone 11 pro with problem was detected with the TrueDepth camera. Face ID has been disabled., and I know that 90% of the issue is to desolder the chip to another flex cable with face I'd corrector, but if I use a flex cable from another iPhone 11 pro and just read and write the code it will still work? Or the specific chip is bound to mother board phone
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Was the display replaced on this device?
完成的
No is just a question , if you a iPhone with face Id problem if you can replace the dot from another iPhone of the same model
完成的
添加一条评论
1个答案
已选择的解决方案
The face Id and front camera module, is similar to the home button on older iphones, in that they are paired to the logic board of the phone they came out of. There is no way to replace it and keep face Id, as only apple has the tools to pair it to the phone. Though depending on what's broken on it you might be able to repair the original module. Here is a guide that might be helpful. iPhone 11 Pro Front Camera Replacement Without Losing Face ID
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Stelios K. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 721
