跳转到主内容
加入维修社区 - 创建账户
2018年10月,谷歌发布的自有品牌手机Pixel的第三代产品。
Pixel 3 won't charge; suggestions for booting/retrieving data?
Hi,
I have a Pixel 3 that no longer charges and has run out of batteries. I noticed shortly before it did that it was at 1% battery. When I plugged it in (or used the wireless charger), the charging symbol turned on and it stayed powered indefinitely, but the % charge never went up. I should have copied my data off—only one thing I need—but instead I attempted to reboot. It powered down and now won't turn on, display anything, or charge.
Any suggestions on how I might get it to power up long enough to copy some data off?
I've removed the back and wireless charging coil successfully, but have stopped there. I honestly don't care if the device ever charges again or survives the process overall, but I also don't really have any ideas on what to do from here.
Thanks for any help!
-Jef
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Can you try to safely take out the battery (without destroying it)?
完成的
@andrewsawesome I think I can. I've disconnected it, though, and that had no effect; are you thinking of getting a pre-charged battery and trying to boot off that? Or something else?
完成的
@puk
Just verifying that there are no previous backups in the cloud that you could use?
完成的
@puk I was thinking of soldering a power supply to the terminals on the BMS board, but a pre-charged battery would probably be easier.
完成的
@jayeff That's correct. (It's unfortunately not really eligible for cloud backup except manually, which is why I should have done that before I powered down.)
完成的
显示更多的2条评论
添加一条评论
1个答案
最有帮助的答案
@puk Generally, a phone will not power up unless a good battery is connected. If the battery really doesn't hold any charge, the symptoms you are describing would make sense, so I would recommend getting a new battery.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jef Pearlman 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 30
总计 234
