跳转到主内容
iPhone won't turn on after charger exploded
I have an iPhone 12 Pro. I was charging it in the wall using a 5W original apple plug and USB-C to lightening cable.
The charger blew up (black scorched and totally melted) and flipped the circuit breaker. I am guessing the capacitor in it exploded.
The iPhone originally had a charge but does not turn on now - just a completely unresponsive black screen. It wont charge with a wireless charger either.
Any ideas on where to start? I can't find any guides on the internet for this situation.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I have the exact same problem, did you ever find out how to fix the phone? I have a iphone 12 and the same thing happened to me.
完成的
添加一条评论
3个答案
最有帮助的答案
The charger likely fried the phone, this is unfixable unless you replace the logic board. That may cost more than the phone is worth.
这个答案有帮助吗?
得分 2
添加一条评论
Hey Rio,
As @guardian10 said, your phone is likely toast.
I'm a little sus about the part you say you use the original 5W charger and a USB-C cable as last I checked, those use USB-A not C.
If you can argue enough with Apple they might replace that phone but if they charge you an absurd amount then SOL. On the flip side if ur into microsoldering, you can use this phone as parts.
Beware of Apple's tricks of trying to get you to buy a new device
Here's a story of mine: I have an Apple watch SE that had software issues so i did the usual. I also had a 4 that was stuck in an infinite boot loop and this specific support person fixed it. Not even the Apple store could do that! Try using Apple support online first so your not screwed over by the Apple store (I don't want to name and shame the specific one as that is just inexcusable so I'll leave it at this)
这个答案有帮助吗?
得分 1
添加一条评论
Check on the battery and display ic
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rio Tinto 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 86
总计 693
