跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
375 个问题 查看全部
iPhone XS Max sometimes doesn't want to charge
When I connect my phone to a charger, it says it's charging, but the battery percentage doesn't go up, stays the same, or goes down after a while.
Yesterday my phone had 10% battery left, I connected it to a charger, the phone said it was charging, I've left it for a few hours and it dropped to 0 and the phone turned off. I unplugged the charger, and after powering the phone on there was no battery left screen with the charging wire, I've connected the charger again, and the charging wire disappeared from the screen. The phone turned on but only charged to 1%.
In the morning I've connected the phone to the charger again and it was charging normally
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try different cable, different plug.
Then you're looking at possible battery, charging port.
After that, it'll be board level repair.
You can scrape out debris in your port, be surprised howuch rubbish gets in there, and compacts everytime you plug the lead in, and you'll eventually just get to that point where there's just enough to cause what you're getting now.
Cocktail stick, or sewing needle with phone off is sufficient to clean out.
这个答案有帮助吗?
得分 0
2条评论:
It's weird, exactly 1 week later it doesn't want to charge again, charged from 20 to 21%, and goes down while saying its charging, now its at 19%
完成的
I don't get it, one day later it charges normally again
完成的
添加一条评论
添加你的答案
Dropper 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 91
