跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
675 个问题 查看全部
Is there a way to repair rubber edges after backglass replacement?
Hello
I have replaced the backglass of an iPhone 8 plus. While removing the cracked glass I have accidently cut the outer rim of plastic/rubber with the razor. I was wondering if there is anyway to repair this or in someway hide the damage as well as possible.
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
It's a type of glue that also black. Most screens use it for waterproofing
这个答案有帮助吗?
得分 0
添加一条评论
It's molded plastic, mold something else onto it, or replace the whole back case.
这个答案有帮助吗?
得分 0
添加一条评论
This is part of the frame. You'll need to replace the housing if you want it perfect.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christian Brink Westergaard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 41
