跳转到主内容
Repair guides and support for Garmin Smartwatches.
Garmin's Forerunner 55 Battery Replacement, is it possible?
I’ve just realized that my recently bought Garmin Forerunner 55 has no apparent way to replace it’s battery.
Am I wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
In theory it should be possible, but just by what I can find on it online it’s going to be difficult to replace. Just by looking at the device I can already tell you’re going to need an opening pick and maybe a heated device to soften any glue holding the screen in place.
Although, assuming that you can get into the device then you’ll need to find a replacement battery. I couldn’t find a new one online, but I’d be willing to bet if you contacted Garmin’s support they would put you into contact with their battery supplier. Otherwise you could maybe cannibalize an old Garmin for its battery.
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries.图片
产品
iOpener
$17.99
这个答案有帮助吗?
得分 1
1条评论:
So to give you the Spark Notes of it. Is it possible, yes. The question is, is it worth it?
完成的
添加一条评论
添加你的答案
Fernando Alves Reisen 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 100
总计 2,526
