跳转到主内容
加入维修社区 - 创建账户
苹果2019年度的旗舰手机发布于9月20日,该设备配备5.8英寸OLED显示屏、三颗后置摄像头,电池续航能力大幅度的提升。为iPhone XS的后续机型。
Screen replacement attempt # 2 - new problems
So this is my second attempt at replacing my screen. This one is the same as last one a hard OLED. I have a new set of issues I’m wondering if it is the screen or if it is something else.
  1. When the phone turns on instead of an all black screen with a white Apple logo it starts off as a dimly lit gray with a washout tone and slowly gets darker and darker until the background is what it should be black.  This washout affect continues on where it’s like it has a frosted effect.
  2. About every three to five minutes the phone restarts. I don’t believe it’s a battery issue because the battery is staying charged.
A detached and attached the cables multiple times to make sure that they were fitted correctly I also took a Q-tip with rubbing alcohol to clean up as well. Anyone have any advice besides going for a third screen?
Everything else from what I can see works including Face ID the back camera I’m able to adjust the brightness of the screen the earpiece and speaker both work I’m not sure what else I’m supposed to test.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Are you using an iFixit screen?
完成的
No I am not. Bought both off of amazon :/
完成的
@David Johnson Do both screens give the same rebooting of the iPhone? (If the scteens came with a home button) Is the home button plugged in during these tests? Do you have a lightning to HDMI (or similar) adapter?
完成的
No they do not . The first one would turn off but then it would not turn back on until everything was disconnected and reconnected. And there was no white haze.
Home button ?
Yes i do have a lightning to hdmi adapter thing.
完成的
添加一条评论
1个答案
Check panic logs, that'll indicate what's causing the rebooting.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 129
