Power light on but tv doesn't come on. Had a bad storm and transformer
Can I fix it or just buy another? Why is it not coming on.
chances are real good the led lamps caught caught in a power surge.
i would not even attempt a repair, as this would be to costly. even you replaced the power suppy and get a standby light on, your led lamps in the screen have also failed.
you may see these replaced on you tube. this is a very time consuming project. under warranty we would receive a new panel (screen) and remove the boards from current tv, and into the new panel (screen). thanks for asking, matt of martins tv repair.
THIS IS A GOOD INDICATION THE LED LAMPS IN THE SCREEN HAVE BEEN BURNDT.
REPAIR IS TO COSTLY FOR REPAIR. THANKS FOR ASKING, MATT OF MARTINS TV.
这个答案有帮助吗?
Thanks for the advice.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 43
3条评论
Can you take the back off the TV and upload a picture of each circuit board in the TV?在已经存在的问题里加入图片
由 Andrew S 完成的
Hi @thyia2022,
What is the model number of the TV?
Was the TV turned on at the time of the storm and was there a general power failure at all?
由 jayeff 完成的
No it wasn't on. I tried to turn it on the next day. Came on then went back out. Hasn't come back on just the led light.
由 Thythyian C Jones 完成的
