跳转到主内容
The MSI GL65 9SD is a budget gaming laptop made by MSI computers released in 2019. Repair guides and further information can be found here.
9 个问题 查看全部
Bent screen after impatct
Just fell off my bike with my MSi GL65 on the backpack and due the impact one of the superior corners of the screen chassis got a bit bent, luckily it didn’t broke the screen, but a light leak is appreciated. So, anything would happen if I leave it untouched? or should i teardown the screen in order to unbent the chassis?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Carlos Plaza sometimes it's best to leave it becasue you may not get it bend nack in shape. Then you are stuck with trying to fit things back together. Post some pictures of the damaged part, light leak etc. with your QUESTION. That way we can see what you see. 在已经存在的问题里加入图片
完成的
@oldturkey03
i added a pic of the light leak
完成的
添加一条评论
1个答案
最有帮助的答案
Hard to say. If the lid opens and closes then you might be able to leave it be. Can you post a picture of the damage?
这个答案有帮助吗?
得分 1
3条评论:
完成的
Not at all noticeable from the photo. I'd leave it unless its really bugging you or you want to try the repair. Light leak is just that, light escaping the edge of the screen. Theres no hazard.
完成的
Carlos Plaza I agree with this answer. Leave well enough alone and enjoy your computer the way it is. Trying to straighten this out would possibly turn into a bigger job than anticipated.
完成的
添加一条评论
添加你的答案
Carlos Plaza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 186
