跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
420 个问题 查看全部
iFixit Battery no longer detected
I just installed a ifixit battery i purchased off amazon into a macbook air 2017.
https://www.amazon.com/dp/B07QPFD2TJ?psc...
It showed sold and shipped by ifixit so im assuming i got a good one.
I did the calibration instructions when i installed it and it seemed to be working great and had good run time. The problem I am having with it is after 3 days the battery is no longer detected by the laptop and just shuts off if i unplug the power.
When i first installed it it did show the battery information but now it shows no battery is even installed even after multiple SMC and PRAM resets. I also disconnected the battery and reconnected it which didnt help.
I did have the computer update from big sur 11.3 to 11.6.2 the next day. The teacher probably had it plugged in all day so i dont know if it happened right after the update.
Is there anything else I can try? Do I send the battery back to amazon or can i send it to ifixit for a replacement?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What does your paperwork say? Source of the shipment. The seller of the battery needs to take ownership of the warranty if there is one.
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
完成的
I added a photo to the top post. The box looked offical and the tracking number was provided by ifixit so im sure it ok.
When i first installed it and charged it after the discharging, it shows 1 cycle count .
完成的
添加一条评论
1个答案
已选择的解决方案
You’ll need to contact the iFixit store to get a replacement this battery is bad iFixit Customer Support Make sure to supply your documentation.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Justin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 57
