Kodak Ektra, battery bloat & power issue. Any replacement batteries?
My Kodak Ektra Android device has had a battery bloat issue for years and the problem got progressively worse until the device is unable to function normally. Are there any replacement lithium ion battery replacements available?
4条评论
@autolooper: I have the same problem with my Kodak Ektra smartphone. The battery drains so quickly that it has to be on charging constantly to be able to use. Did you manage to change the battery as @oldturkey03 described?
由 santioriginal 完成的
I have not been able to move on repairs yet as I also need to deal with the case being destroyed by the bloated battery, D:
由 Michael Tang 完成的
@autolooper I'll go this week to a gsm repair shop with my Kodak Ektra. It's an "obscure" device, but maybe they can fix it with / have the skills. I'll let you know.
由 santioriginal 完成的
I contacted support@kodakphones.com (bullit-group.com).
This is their answer:
Thank you for contacting Kodak phones support.
I'm sorry to hear the battery is no longer holding charge when it's disconnected from the charger.
Please be advised that we no longer create or support this phone model, so I've contacted our service centre to double check whether this can be repaired.
Once I have an update regarding whether this can be repaired, I will let you know.
Alternatively I kindly recommend checking with your retailer whether they can assist further.
Best regards,
- Kodak phones support
由 santioriginal 完成的
