跳转到主内容
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
phone wont turn on unless plugged battery was replaced with orginal
so my screen was broken and i went to phone shop to get it replaced i replaced it however when i got back my phone was not turning on so i kept it on charge and and it turned on and when i took it off the charger it would work for a bit then turn off. initially i though it was the battery and charging port because it was old so i decided to go to the shop the next day and get it fixed. so they replaced my battery and charging port and when i got home it was still turning off when it was not plugged in and refuses to turn on when it isnt plugged in. i have reseted it and still no luck
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Aadarsh Biju since you already replaced the battery and the charging port and " it was still turning off when it was not plugged in and refuses to turn on when it isn't plugged in" you will have to take a look at the board level components . Follow the flow sheet for the No Power troubleshooting
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aadarsh Biju 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 74
