跳转到主内容
苹果2019年度的旗舰手机发布于9月20日,该设备配备5.8英寸OLED显示屏、三颗后置摄像头,电池续航能力大幅度的提升。为iPhone XS的后续机型。
148 个问题 查看全部
I’m ready to throw this phone across the room!
Replacing screen.
I’m on my second screen.
Everything is connected.
# Phone turns on, I can hear and feel the vibrations.
  1. Screen is responding to my touch.
  2. Screen is black, I cannot see anything of the screen and/or a very dimly Apple logo upon start up.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I’m so frustrated!! I don’t know what to do
完成的
添加一条评论
3个答案
最有帮助的答案
This is the symptom of a faulty ambient light sensor. It might have got damaged during the screen replacement.
这个答案有帮助吗?
得分 2
添加一条评论
hello David,
it seems to be like faulty new screen panel, it happens sometimes. But, most cases (you nothing write about a reason of change) its just a badly inserted screen connector into the port. Don't forget about first important electronic rule - battery firs when unplugging and the last when pluging.
It would be a good practice to go to a nearby repair shop and have your screen checked. It shouldn't cost a lot, just plug it in and check on another phone if it's not working. If, however, we'll wonder later.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the reply... I have two screens .. the first didn’t work, so I bought another.. do you think I could have damaged one of the prongs? Causing no light? Idk? It’s sitting away from me right now, as jt is so frustrating
完成的
it's hard to answer your question without touching the phone. The 11pro model has an OLED screen, so different rules apply here than in the LDC models. If the OLED screen does not work, if it is not damaged, it has a problem with the power supply. All the more, give the phone to a good repair shop, even for diagnostics. You will learn everything - you need to measure the ports with the current, check the screen. You may find that you now have two :-) working screens :-). Fingers crossed.
完成的
添加一条评论
I'd second popping into a shop and see if they can test another screen for you.
You could try a soft reboot.
Or even dfu mode restore.
Sometimes, the aftermarket screens have ever so slightly bigger fpc connectors, and these can stretch out the board connectors, but this is rare.
Is It an oled or LCD replacement?
这个答案有帮助吗?
得分 0
1条评论:
it is an oled screen
完成的
添加一条评论
添加你的答案
David Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 122
