resetting air bag light.
I worked on my steering and after the air bag light came on. how do i reset
Here's a video on how to do it: http://www.youtube.com/watch?v=fBTDc_Gwa...
这个答案有帮助吗?
+ research and for not avoiding LMGTFY ;)
Video is a waste of time isnt even close to being a how to reset airbag on a 7th gen corolla/prizm ....
Answer is further down
Sean, looks like they have changed the video on the link. This question is 6 years old.
I myself had the same problem. What I had seen in a post about a Lexus with the same problem, I tried it about three times and it worked for me! He connected three wires to a three prone switch, (the same as people use when something false in their car or they want switch to turn something off or on). So on the switch you will have three places to hook up the wires! The ground I placed in the middle and AB on one side and TC on the other! Instead of what I read in most of the post about this thing, I started with the switch on TC and just flipped it back and forwards from TC to AB a couple of times and stopped on TC! Air bag light started to flash continuously, unhooked wires and air bag light went out! Forgot to include before you start this procedure the ignition switch needs to be in ACC or ON!!
这个答案有帮助吗?
I have a geo prizm 1993 air bag ligth on, I tried all does preceding and don't work
这个答案有帮助吗?
I have a geo prizm just I change the cluster and after that air bag is on, some body can help me how reset it. Geo prizm lsi 1993
The following procedure does work!
Only step missing is prior to turning ignition on ground tc and ab with 2 seperate wires. Then turn ignition to ACC/On wait 6 seconds then using just one ground wire quickly ground tc ab tc ab tc. Took me a few tries but i didnt ground ab and tc at the start so make sure you do that everytime if it doesnt work reset ignition and repeat
I could use some help same issue. What and where on a 96 camry is tc and ab? And If tc is grounded already and ab is grounded already (like to the battery?), then what is being grounded in tc ab tc ab tc that makes any difference to these being already grounded?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 26
总计 17,728
2条评论
Please change your chosen solution because its incorrect. Video posted is for resetting maintence light... Not the airbag
由 Sean Miranda 完成的
The video is for clear the maintenance light. NOT the SRS light.
由 Lone Star 完成的
