跳转到主内容
A lower end smartphone released in March, 2014 running the Android operating system. Also known as Nokia Normandy, Noxia A110, and Nokia X Dual SIM RM-980. Repair of this device is similar to other smart phones and requires a screwdriver and prying tools.
13 个问题 查看全部
Forgotten pin code for Nokia G10
My daughter has reset her Lock Screen pin and can’t remember what it is. Is there a way to unlock or reset the device or even someone I could send it to?
It’s a Nokia G10
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
3条评论
My Nokia g10 has no sound everywhere... what should i do?
完成的
الهاتف يعلق كثير
完成的
الهاتف يعلق كثير في تفسيره
完成的
添加一条评论
2个答案
最有帮助的答案
Hi Bret,
I also had this problem recently. I have found a working solution on this article:
https://unlocky.org/unlock-screen/unlock...
I've used "method 3" from the list, so you may need some IT knowledges :)
这个答案有帮助吗?
得分 1
添加一条评论
Use Google's "Find My Device" tool to erase the phone remotely.
Make sure the phone is turned on, and open this link from a computer:
https://www.google.com/android/find
Sign in to the tool with the Google credentials you used when you first set up the phone. Choose the phone on the list, and click ERASE DEVICE. This will erase the phone and allow you to enter a new PIN.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bret Gillies 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 989
