跳转到主内容
iPad (第七代) 的維修以及拆卸指南
I replaced the headphone jack, now it doesn't work.
I do iPad repair for a local public school and I have not successfully replaced a headphone jack … I am using #40755197
After replacing it, it just doesn’t recognize that my test speakers are even plugged in to it. Sound continues to play from the device speakers. Faulty part or faulty repair?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I would check all connections. See if you just didn’t seat something correctly. If that does not work than it is most likely a bad part or (possibly) logic board issue.
这个答案有帮助吗?
得分 1
4条评论:
So I replaced the headphone jack due to a broken piece being stuck in it and unable to extract it. So it worked prior to my replacing. I have disconnected and reconnected it three times. It just seems hard to believe that the logic board failed during repair (battery is disconnected)
完成的
@sabretechtech It's not necessarily that the logic board failed, it's more that it's possible something got nudged or knocked loose during the course of the repair. Accidental pry damage is not uncommon when trying to unplug connectors from the board, even if you're an experienced tech. I have done it more than once my own self.
That being said, I would assume bad part first, but I would still check around the connector anyways, may sure no pins are out of place, or small components are loose - I realize this is difficult without some level of magnification, but it's worth having a look.
完成的
@flannelist Alight, so I inspected the connector under magnification, it appears good. I installed the original port back into it and it recognizes that there is something plugged in (the broken piece) So I believe that verifies a faulty part. I wonder if ifixit.com will still give me a replacement? I keep it in stock, but it was ordered almost a year ago.
完成的
@sabretechtech I would definitely reach out. the store page lists a lifetime warranty even on parts.
完成的
添加一条评论
添加你的答案
Aaron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 74
