跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
MacBook won't always power on
I've had some interesting problems with my Mac recently, it won't boot or respond to the power button. However sometimes it will just boot at random regardless of if I press the power button but as soon as I close the Mac or it goes to sleep it completely shuts down. solid green magsafe indicator and no signs of life from it. Can't reset SMC or pram as it is acting as if it is completely shutdown or out of battery. Any advice would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
完成的
@danj But I cannot boot my MacBook and now after it randomly turns on it will shutdown within a couple minutes and be totally inoperable. I can't control when it comes to life. I don't think I can get it to stay on long enough to install software. Thanks though
完成的
添加一条评论
1个答案
Disconnect the battery following this guide 2017年早期MacBook Air 13寸 电池更换 stop at Step 3
Now press & hold the power button for 15 secs with nothing connected. Next carefully plug in your MagSafe charger. does the system startup and stay running?
这个答案有帮助吗?
得分 0
6条评论:
I unfortunately do not have a penta screwdriver however I could get one from a friend.
完成的
@Nicholas Gray - Beg, Borrow or Steal ;-}
完成的
@danj nothing. I did a SMC reset which worked as the status led went from orange to green then back but still no signs of life.
完成的
@Nicholas Gray - Not good your logic board is bad.
完成的
@danj can anything be done about that other than just replacing the board? What confuses me is sometimes it will just turn on, either from a really long delay or just randomly. And then the computer will function as normal for 2-3 minutes then die
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Nicholas Gray 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 107
