跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
258 个问题 查看全部
Vertical lines on screen+external display stuck on apple won’t boot
No water or screen damage. Vertical lines on both computer screen and external display. I’ve tried all reset procedures. It will not boot in safe mode. Ran hardware test and it came back with no issues. Is this a gpu issue? or a kernel panic?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Can you post some pictures so we can see things. It would be helpful to see both the internal and external display at the same time (maybe a video) 在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
Wow! Not good ;-{
I was hoping the issue was the display as that would need a new display.
In this case your video RAM is messed up, this will require either finding someone with deep micro-soldering skills or you’ll need to replace the logic board.
Update (02/10/2022)
Sorry replacing the VRAM is not a trivial job! You need some special tools and access to the needed parts which are hard to come by on the open market.
Here’s a view of the logic board, the Yellow marked chip is the GPU and the four green marked chips around it are the VRAM chips
这个答案有帮助吗?
得分 0
1条评论:
Shoot. That’s not what I wanted to hear. I took the cover off to see if I could see anything visibly wrong with a display cable or something, and randomly it started working again. I tried to pull up the errors in the console and there seemed to be a lot of gpu, and “google helper” being listed. There was a software update so I started that, and when I came back the screen was black and unresponsive. I held the power down to reset and now it’s back to the vertical lines and the apple logo. Is there instructions that I can attempt with the video ram, before i replace the logic board
完成的
添加一条评论
添加你的答案
Brennan Lammermann 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 23
总计 277
