Battery Not Charging, Only 1.2V at Terminals
What could cause an Ipod Touch 2G to only have 1.2v across the battery terminal when plugged into USB? I replaced the battery with a known good one and the issue remains. When I remove the ipod from the USB cable, the voltage drops to 0.25v.
I dont know if it could be the charing port or the Power Management IC?
Thanks!
2条评论
I left it plugged into an AC adapter for a few hours and the results are the same. Not sure what else to check. I think something may be shorted out...??
由 AnthonyM84 完成的
Check your dock connector and see what you get. Checked the connector to make sure the pins are okay? Also, your battery is a new one or used one? I'd go with the easy stuff first.
由 oldturkey03 完成的
