跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
259 个问题 查看全部
MacBook Pro startup chime (5 times), no Apple logo
Hi all,
I was just in the progress of backing up all my data of my “old” MacBook Pro 15” 2016 with touchbar. That progress finished. When I came back to the MacBook Pro, it was shut off, so I tried to turn it on again.
However, now I hear the chime when booting and after a “full” chime, it sort of echo’s 5 chimes after that on low volume. When plugged in the charger, it keeps trying to boot. You’ll hear one semi-loud full chime, and them 5 small chimes. No Apple Logo, no backlight, nothing.
Tried resetting the NVRAM, SMC and everything I could find, but it just keeps trying to boot up. Screen doesn’t show anything, tried to connect it to a monitor, but still the same. It looks like something in the boot process fails or hangs.
Any suggestions?
Thanks in advance!
Update: Added video
https://youtu.be/r_rsLTQOXqc
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
What happens when you hold option during start up? does it show the boot disks or just shut down? It might be a failed update that didn’t install properly. Ive seen many of these model MacBooks with stuck on Apple logo being caused by a failed update or OS upgrade. It is usually caused by the computer loosing power or WiFi connectivity during an update. If you hold option during boot up and see multiple disks like Macintosh HD and another disk called macOS Installer or macOS Update then that was the issue. Sometimes if you choose to boot into the installer disk it will fixi itself if you leave it alone for a while and make sure you are somewhere where you will automatically connect to wifi. Hope this helps!
这个答案有帮助吗?
得分 0
1条评论:
Tried that, but still the same. I've added a video in the post. Tried the Power + T and connecting it to another Mac, but the MacBook doesn't seem to listen to any keyboard input. It looks like the bootloader fails or something.
I haven't initiated an update by the way. I haven't updated it to macOS 12, because I was about to wipe it. But before I could do any of that, this happened. I didn't start the process of formatting the SSD yet, to be clear.
Thanks for looking into it though!
完成的
添加一条评论
添加你的答案
Bart Versluijs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 115
