跳转到主内容
惠普 Chromebook维修指南。
162 个问题 查看全部
11 G3 EE chromebook Keyboard sometimes doesn't work
My chromebook recently has had the z x c v m , . space bar and even the left shift key stop working, b and n are still functional, even more strange is that sometimes the keys work perfectly fine with no issues, other times they don't register at all, if I plug in a USB keyboard or use the on screen keyboard every key works fine, so I don't think this is a software issue, I checked under one of the keys and found no dirt, even tried to push down the pad myself, and the key sometimes still didn't register, help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @catlove ,
Here’s the maintenance and service guide for the laptop.
Go to p.26 to view the necessary pre-requisite steps and then the procedure to remove the keyboard/top cover assembly.
Doing this will allow you to inspect the keyboard cable connection to ensure that it is secure etc.
If it is then most probably the problem is internal to the keyboard. Most times when trying to repair keyboards you can create more problems than what you originally had and it is easier to simply replace the keyboard.
On p.24-25 you will find the spare part numbers for all the country specific, compatible keyboard/top cover assemblies. Search online using the appropriate to your particular model variant part number only, to find suppliers that suit you best
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Connor Steffenhagen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 128
