跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 个问题 查看全部
Is this battery compatible?
I ordered a battery for my MacBook Pro Retina, 15-inch, Late 2013 2.3GHz , 11,3, A1398 (EMC 2745).
I ordered the battery that corresponds with this MacBook, (late 2013-mid 2014)
I Just received the battery and it says on the battery “Compatible with model number: A1494”, no mention of my actual model number, is this battery replacement fine or do I need a new one?
I went through the intuitive iFixit model finder and it gave me this battery when I input all of my information. Any help would be appreciated!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If we look at the needed battery from iFixit we can see the details MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery
Model #: A1494
Watt Hours: 95 Wh
Voltage: 11.26 V
Milliamp Hours: 8440 mAh
Manufacturer: Aftermarket
So you did receive the correct battery as this is listed as a A1494
Keep in mind the computer model is not the same as the battery model. So follow the guide here 2013 年末期带Retina显示屏 MacBook Pro 15" 电池更换 and you should be fine! Make sure you use the solvent sparingly! A little goes a long way and take your time! Slowly lifting the battery and putting in a bit more in-between the battery and the case.
MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery图片
产品
$89.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Marcos H 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 76
