跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
150 个问题 查看全部
iPad 5 LCD Not working in iPad 6?
Strange One.
iPad 6 has come in with a busted LCD. I have a new tested and working LCD from a iPad 5 and its just showing static (grey dots etc with no picture visible).
I tried a damaged but still working iPad Air LCD with the same issue.
I then found a damaged but still working iPad 6 LCD and it worked no problem at all apart from the already known damage as its a test LCD.
I tried both LCDS that didn’t work in the iPad 6 in a iPad 5 and the new LCD worked perfectly and the other worked as advertised (Had some damage as it’s a test LCD)
Considering iPad Air 1,5 and 6 LCD’s are combatable has any one else come across this or have a solution?
Note - I did try a reset with all LCDs plugged into the iPad 6
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Aa far as I know, iPad 6 LCD is backward compatible with 5 and Air, not vice versa.
Replacement screen advertised as cross-compatible for Air/5/6 is essentially an iPad 6th gen LCD, that is why it’s pricier than Air/5 LCD.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 155
