跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 个问题 查看全部
Will not read install disc just spits it out
Just got an iMac from my dad. It is an older one but he never had any problems with it. I purchased the snow leopard upgrade and have been attempting to install it. The drive just sounds like it is trying to read it and spits it out. This was an issue when I was trying to burn files to a disk to save for my dad prior to the install, but after putting them back in a few times it ended up working. This is not the case with the install disk! I have tried multiple times. It did load once, said I had to restart my computer (which I did), after the restart it spit it out again and wouldn't read it. I am so frustrated! Not sure what else to do at this point... Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
You can replace the drive or, better yet, get an external DVD drive that you can use on other machines. I personally like the LaCie drives, USB/Firewire dual layer.
这个答案有帮助吗?
得分 4
添加一条评论
Have you tried to start-up the machine from your Snow Leopard Install Disc? Is Snow Leopard already installed on the machine or is it running Leopard? If it is, you may have to upgrade to the most recent version of Leopard before you install Snow Leopard. It's not always a hardware problem. HTH ;P
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kelly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 897
