跳转到主内容
雷蛇笔记本电脑的维修和支持指南。
151 个问题 查看全部
fans are grinding or making a strange noise
I have a razor 15 2019 and it sounds like the fans are grinding or making a strange noise but are working fine. I want to properly clean it and if possible increase my ram from 16GB to 32GB
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Max Regni Let us know the exact model for your Razor.
完成的
添加一条评论
2个答案
最有帮助的答案
Max Regni looks like teh part number for your computers fan is DFS5K121144645. check places like this for a replacement. As for the memory we would need your computer model number to determine what you need. for now it looks like you would need
  • DDR4 PC4-21300
  • CL=19
  • Dual Ranked
  • x8 based
* Unbuffered
  • NON-ECC
  • DDR4-2666
  • 1.2V
Double check with places like this
这个答案有帮助吗?
得分 1
评论:
my system is the blade 15 mid 2019-base and I am somewhat computer literate but I don't know what any of that means besides that ddr4 has good speeds and that if possible I want my ram to be duel channel
完成的
Max Regni you will need this when you order your memory. Of course if you use Crucial etc. you'll find that there website is really user-friendly and based on your computer. It'll be straight forward, no worries about that.
完成的
添加一条评论
I would do some research b4 upgrading. I found a number of posts that indicated a 16 to 32GB RAM upgrade has little effect unless you are doing some serious number crunching or video editing.
As far as the noise, it may be as simple as dust needing to be blown out, or the fan bearings need lub or maybe the fan needs replacement if they are real bad.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Max Regni 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 18
过去的30天: 88
总计 502
