跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone 5 Won't connect to PC
I’ve just replaced the battery on this iPhone 5 as previously it wouldn’t boot up at all. It now functions normally and charges from the wall and mains power supply. However I’ve connected it to my PC with several lightning cables and it’s not detected by Windows at all. The phone won’t charge from the PC and there’s no Trust Computer message. I read that it could be a faulty U2 Tristar chip, can anyone confirm?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It could be a tristar problem, but first you’d need to rule out a bad charge port. You can order one and then just connect it without fully installing to see if that is the case. If it does need a new tristar then that’s a microsoldering job.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nuggets321 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 23
