跳转到主内容
The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
159 个问题 查看全部
Disc drive won’t read discs, just pulses.
My Xbox one x disc drive won’t read discs, it pulses like it wants to start but doesn’t continue.
So far I tried initially replacing the laser with a new one, that didn’t work so I changed the whole drive and swapped the board over, that didn’t work either.
Tried power cycling and also changing the power settings so it wasn’t on standby but nothing hasn’t worked.
Any help would be amazing please ??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Have you made sure all the wires are working right take a multi meter and pi it into Continuity mode and then check the ends match the ribbon cable End-to-end With the corresponding pads on each side then make sure that you test each individual pad 1 by 1 That way you can tell whether or not you have a short in the actual wiring itself ribbon cables are very delicate and can easily break or overheating of the device it is can cause them to fry. If that doesn't work then again in the same mode test the processing chips in charge of encoding the video in the motherboard because if you are not getting the disk read and have changed out the laser diode the the problem is on the motherboard itself. Hope that helps!!
这个答案有帮助吗?
得分 0
1条评论:
The complete disc drive is new, so think it is more likely to be the board then, which chip exactly is it?
完成的
添加一条评论
添加你的答案
Nick Comley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 133
