跳转到主内容
Repair guides and support for a wide range of kitchenware.
70 个问题 查看全部
Electric Kettle safety microswitch
Many kettles have a microswitch which needs to be depressed by the kettle being in place before the element gets power. (This is true for many makes). Often we get broken microswitches and they seem to be embedded in the mechanical trip/on/off switch in the base of the kettle - no chance of fixing the microswitch and apparently no way of obtaining a replacement mechanism. Do other repairers have the same problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @nhcw62 ,
Yes. I think that planned obsolescence is the business model of the manufacturer. Maximizes profits by producing low cost products and not having to keep a spare parts inventory or a service repair section
With some brands sometimes you may be able to source replacement parts, except usually the element when it is encased in the body of the kettle. Search online for (insert make and model number) parts. You can be lucky sometimes
Another option is to source used ones on Ebay, Gumtree, rubbish tip recycling shops etc where hopefully the same problem hasn’t occurred to the product. Depends on the condition, price and how desperately you want to fix it.
Just my view.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nigel Ward 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 16
