A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Ryan Caron @ryancaron
声誉积分: 1
发帖于: 2022年1月10日
Hi I just have a quick question when I turn on my pc the monitor won’t turn on I check the hdmi of the monitor and tight it it’s still not working.
这是一个好问题吗?
1条评论:
Hi,
More information is needed to help you.
Is the monitor powered on and does it have a message on the screen e.g. "no signal" or something similar?
Can you view the monitor's menu screens OK?
have you tried another monitor e.g. TV?
What is the make and model number of the PC motherboard?
Make and model of CPU?
Does the PC have a GPU card or are you using integrated video?
is the PC booting up OK?
What else have you checked?
由 jayeff 完成的 2022年1月10日
Medo ABDELAAL @medoabdelaal
发帖于: 2022年3月28日
if you have a gpu be sure you connected hdmi to the gpu if you don’t have connect the hdmi to the motherboard
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 57
Hi,
由 jayeff 完成的
