跳转到主内容
Face ID not working
My Screen was damaged and I’ve got a replacement but the ribbon cable off the original earpiece assembly was also damaged and I’ve had to also replace the assembly. As the sensors are paired with the phone once replaced the Face ID is not working. Can the new assembly sensors be programmed to work with the phone to re-enable the Face ID feature?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Unfortunately, the Face ID assembly cannot be repaired under any circumstances except by Apple or their authorized service providers. Face ID data is stored in something called the Secure Enclave in your iPhone. Any attempt to remove it to perform a repair or replacement will result in the secure enclave chip being destroyed or disabled without question, not to mention the data is secured digitally. This is impossible to reprogram yourself; I’m sorry for the disappointing response, but it is the truth. :(
这个答案有帮助吗?
得分 0
2条评论:
Hi Marcus, thanks for your response. Do you think it's possible to replace or repair the ribbon which connects to the front earpice assembly?
完成的
Hey again, not a problem at all! While I can’t say for sure if this would be impossible, I do know that Apple employs tamper-resistant measures in this technology. If your device detects damage or any sort of tampering, there is a good chance Face ID will be disabled even if it is still functional. It may be worth a shot, but I would again advise that the chances are unlikely. I’m sorry for such disappointing answers :(
完成的
添加一条评论
i have same problem on several phones, i believe that there are 2 components that you need to transfer to new flex and it will work, i will update when i receive new flex cables and do the swap - look on youtube - resq
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
shaun Henderson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 216
