跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
904 个问题 查看全部
Brand new hard drive already corrupted
Hi folks. My ipod classic started freezing/stopped playing songs, itunes said it was corrupted so tried a few different fixes which worked temporarily but in the end I bought a new ssd and installed that. Now after less than a week I am experiencing the same issues making me think it might not be the hard drive that is the cause, maybe the logic board, maybe itunes itself?
Any suggestions would be greatly appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@chrisniow this could be based on your ROM/RAM. Double check the size of your library and your firmware version.
这个答案有帮助吗?
得分 1
9条评论:
Firmware is as up to date as possible (2.0.4) and had higher bit rate songs set to download at 286kbps. Have now set to 192 kbps which seems to have temporarily fixed the issue, but it seems strange that this has only happened recently and there was still about 80gb free on the old hard drive and now 194gb free on the replacement hard drive. Don't suppose you have any other insight?
Thanks for the help thus far though!
完成的
@chrisniow I do know that if the library is to large the ROM/RAM can't do the processing and will exhibit symptoms pretty much like your iPod is having now. Even this "286kbps. Have now set to 192 kbps which seems to have temporarily fixed the issue" points to it. What model is your logic board. There should be a 820-XXXX number on it.
完成的
@chrisniow 8000 songs is still a lot! Try putting only about 100 songs on your iPod and see what happens. If it works fine then you have too many songs. Of not then you may have a logic board problem.
完成的
@oldturkey03
Yeah library is only 8000 songs. Same issue is now happening as before after dropping to even 128 kbps.
where would that number be located? I can't seem to find find an 820 number, nearest thing I can find to that grouping is 805 - 7973 but thats on the housing for the usb connection
完成的
@diode_cool Its definitely getting to the point where it seems to be the only option, it just seems super strange to me that it basically happened out of the blue? I hadn't added any new songs before it started playing up and they are supposed to be able to take up to like 20,000 songs right? So 8000 should be a breeze
完成的
显示更多的4条评论
添加一条评论
You can get a new motherboard there is a place that has all of the parts for ipad classics. I would have to look them up if you are interested.
这个答案有帮助吗?
得分 0
1条评论:
Where can you find motherboards? I had a look but couldn't find a retailer? Although I'm not keen on getting a motherboard unless I know thats actually the problem
完成的
添加一条评论
添加你的答案
chris north 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 82
