跳转到主内容
加入维修社区 - 创建账户
The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
Can I get any graphics card and flash it
I can’t afford people selling there “Mac pro 2009 graphics card (HOWEVER MANY GBS)“ can I get a card and flash it with firmware for a compatible card with Mac Os Mojave,
Also how hard is it to flash a card
@danj
@oldturkey03
@mayer
@jayeff
UPDATE 4/25/2022:
How did apple mess up this much!?!?!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Your MacPro can support quite a few graphics boards. But!! The primary needs to be the one Apple sold with the MacPro systems. Its not altered (unlike the iMac (MXM bds) its just Apple needed a way to have the system access a known graphics board as the Xenon CPU’s don’t offer an internal graphics service unlike the Laptop and other desktop systems Apple makes.
Think of it this way… Every 2010 15” MacBook Pro and 27” iMac onward has dual graphics! The Intel graphics are the default graphics in these systems. And the needed driver support is within the EFI firmware. Within the early MacPro systems the default graphics is the video card sold with the system.
这个答案有帮助吗?
得分 4
33条评论:
@danj
I would get one of these ATI Radeon HD 5870s
But they only have 1gb of Graphics Ram,
I'm wondering if i put a other GPU in the 2nd slot and kept the Gt120(APPLES card) in the 1st slot would that work?
完成的
@beanman56 - Yes! You can have both cards installed and you can define the primary display to be the second board.
完成的
@danj what card you think would be best?
I don't want to get a bad card,
And not one apples not so good cards (or not anymore at least)
would this be a good one https://www.amazon.com/MSI-RX-560-AERO-I...
完成的
@danj also how would i define the second card to be primary
完成的
@beanman56 - Did you review the links I posted?
As far as defining which is the primary display that's done within the Display control panel.
There is two aspects here, the primary video board and what is the primary display once the system is booted up.
One of things people mess up is they take the Apple board out and either sell it or loose it! Then they need to re-install or update their OS only to find the need for the Apple board is required.u
完成的
显示更多的28条评论
添加一条评论
添加你的答案
Ben Capehart 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 53
总计 2,120
