跳转到主内容
Repair and modification information for the Creality CR-10S Pro, a 3D printer from the CR-10 series released in 2019. This first version was succeeded by the CR-10S Pro V2.
7 个问题 查看全部
I need help in replacing my nozzle and bowden tube in printer
I am looking for someone to help tweek my 3d printer. I recently had to change a nozzle from a clog and it is not printing as good as before the clog. I live in RI. I can bring my printer to them ot they can come to my house.Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
where are you at im in colorado
完成的
添加一条评论
1个答案
Hello! so to replace the bowden tube and nozzle, you want to heat up the nozzle to around 170C. then use the small wrench in your creality kit to unscrew the nozzle (youll need to unscrew it clockwise i think)
to remove the bowden tube, you'll need to
first remove the blue clips from the tube (from the extruder side and the hotend side)
push down in the white plastic nut/part till you hear a soft click
pull the tube you
another way is to use the large wrench to unscrew the big nut on either side of the tube
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
booboo759 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 91
