Machine won't start after moving it with a dolly about ten feet
After moving machine to do some work behind it and then putting it back, the washer made a weak attempt to start, then no sign of life. I moved it straight back from the wall then came in from the side with a dolly to move out of the way. Will tilting it cause an issue?
Hi,
What is the model number of the washer?
Did you move it with the power cord still plugged in?
If there is no indication of power on the machine check if the power cord connections in the machine are secure.
由 jayeff 完成的
