跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
150 个问题 查看全部
Replaced the digitizer and there is a strip that is not responding
Hi all,
Having issues working out why one digitizer has a strip near the bottom that does not work after been replaced. started a draw program and all along the screen there is a strip that does not work.
The ebay seller said the screen was fully tested before shipped.
I bought 2 from the seller and the other screen does work (although i did manage to break the home button cable :D
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The part is defective, sometimes defects take a while to present themselves or damage occurs during shipping or the part was never actually tested, you never really know which one is the case. The home button can be replaced fairly easily, although the home buttons on iPads are a lot trickier to get set properly compared to iPhones.
这个答案有帮助吗?
得分 0
1条评论:
I took the iPad up to a repair shop up the the street. he looked at the connectors on the ipad and on the replacement screen and said there was nothing wrong with them.
Is it correct to assume that the film on the back and front of the replacement digitizer can stay while you test it? should not affect this i hope?
完成的
添加一条评论
添加你的答案
Ronnie Jorgensen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 24
