跳转到主内容
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 个问题 查看全部
How to secure front rubber impact strip to it's bumper?
My 1985 300D front rubber trim is loosening from it’s bumper. I tried to get the clips back into place and slide the impact strip into place. Unfortunately, it will not remain snug.
Advice and directions to fix would be most appreciated.
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like your not getting the clip far enough onto the rubber backing . A near impossible task on dry rubber. If you were to spray the rubber with a spray lubricant like liquid wrench or wd40 you’ll find you can push the clip on further and then when you assemble your fit will be tighter. Hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Scott Henson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 108
