跳转到主内容
A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 processor. Released March 19, 2019.
78 个问题 查看全部
My İMac wont work as expected
so this İMac i got in March 2021 is not working as it is supposed to.
it both froze and the clicks on my mouse didn’t register when the movement did today.
is it motherboard or cpu or maybe ram or big sur 11.2.3 that is having issues?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
sounds to me like its a hard drive related issue.
完成的
Yeah
İt may be hard drive
完成的
Is the hard drive on this machine backed up?
完成的
@andrewsawesome i never backrd it up
完成的
@KAAN CAN I would recommend backing up any important data before we continue.
完成的
添加一条评论
2个答案
已选择的解决方案
@KAAN CAN
Problems it could be in order
  1. Drive
  2. Big Sur
  3. motherboard
  4. And if the ram was the problem it would be having purple lines on the screen right now,
  5. i don’t think the cpu could be the problem
这个答案有帮助吗?
得分 1
添加一条评论
What you didn’t mention was whether you were using a wireless mouse and keyboard or one that is using one of the USB ports.
If using wireless, you might have a wifi issue, either the wifi in the machine software is corrupt or there is a hardware issue, or the batteries are dead in the control devices.
If using wired control devices, you might try using a different set (keyboard and mouse) from a known running system, and try them on a different USB port.
Did you upgrade the system to Big Sur, or did you get the machine with Big Sur already installed?
If you shut the machine down by holding the power button down (provided you have no control of the screen to initiate a proper shutdown) and then do a restart, do you get the startup chimes, or some sort of coded beeping? If you get the chimes, the machine is happy with the ram.
If the machine starts with the chimes, does it go to a log in screen, or if you’ve selected to auto login, does it go to your desktop? Or do you get a question mark or some other odd looking icon?
这个答案有帮助吗?
得分 0
1条评论:
İt boots normal,it has magic mouse and keyboard(they came with the imac)not wi-fi since i can join online classes eighter
İt came with catalina but i updated it to big sur in day one,no weird icons eighter
完成的
添加一条评论
添加你的答案
KAAN CAN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 69
