跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1014 个问题 查看全部
My Back Glass is shattered. How can I fix that myself?
I just bought a broken iPhone X off eBay to repair and resell but the rear glass is broken and I can’t find a solution as a beginning repairman.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This looks like a good video on how to do it!
You just need a bunch of heat and some Xacto knives :)
But make sure to disassemble the phone all the way first like they do in the video, otherwise stuff inside will probably get ruined.
When buying new glass for it, you have to make sure you get an aftermarket piece with a slightly oversize camera section, since the glass normally goes under the edges of the camera bump, and then it is permanently welded in place from the back.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mtdecamp@icloud.com 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 12
